Results 1 to 4 of 4
    Apr 2004
    Jax, FL
    Question Wiring for high press fuel pump 2000 Moomba Mobius V
    Having trouble installing the new retrofit hp fuel pump. Does anyone have a correct wiring diagram?
    Going to be a tough one to find on a boat this old...
    Aug 2012
    Morganton, NC
    Default Re: Wiring for high press fuel pump 2000 Moomba Mobius V
    I've got a couple more of those don't help. Need to know what type of ignition you've got to narrow it down. Leaving tomorrow around 2 for a little boat vacation myself, book is staying at the house for good luck...
    Hope it helps.
    Sent from my S3 using Tapatalk 2
    2008 OBV
    325 EFI with closed cooling
    Gravity III with 750's in the rear, 400 stock floor
    Wetsounds Pro 80
    JL Amps, WS420BT
    2000 Outback LS <-- Sold!!!
    310 Carb Direct Drive
    800# Rear Locker
    Kenwood Head with Remotes
    Great stuff! Where did you get this?
