Results 1 to 10 of 18
    Jun 2013
    rockwood tn
    Default trouble fueling my mojo 2.5
    The gas over flows every time I put gas in it I have to sit and baby sit it when filling even when its almost empty any one else have this problem or Andy ides that would help me??
    how are you filling - from cans or at station?
    is your boat a '12 or '13?
    never had any issues with mine.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Aug 2012
    Quote Originally Posted by Riddle2.5 View Post
    Both of my Moombas do/did that.
    I just listen closely and you can hear the gas tank getting full. I'd be interested if there is a way to fix this. I would prefer it shut off like a car.
    Nate
    2008 XLV GG (sold)
    2013 LSV
    Aug 2006
    My 04 outback did this. Fuel full hose was cut too long at factory and kinked a bit. I shortened and voila!
    Not sure how easy access is in mojo but that was fix for mine.
    One check on that would be to unscrew the screws that hold filler neck on hull and see if it pops up when loose or If it takes enough pressure off kink.
    It's only a hose running straight to tank so most probably a bend or kink.
    I understand the frustration. Guy I bought from said it was "normal". Dealer said no issue. I wouldn't accept that!
    Brad
    Mississippi/Louisiana
    2011 Launch 21V
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Quote Originally Posted by NateHaskovec View Post
    new boats will.
    http://www.moomba.com/msgboard/showt...ht=fuel+system
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Aug 2012
    From experience (at least 10 times filling my 2013 LSV), it doesn't. When it gets full, it spits gas out.
    Just ask my gas station about the guy who fills up with a microfiber towel in his hand.
    Nate
    2008 XLV GG (sold)
    2013 LSV
    does your boat have the new fuel system? some 2013's do not.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Apr 2013
    DFW
    My 2012 LSV burps all the time when filling up. I have to keep paper towels held up below the nozzle to catch the overflow. It is almost as if it doesn't vent as it should. I might see if I have a kink as well.
    Matt
    2012 LSV
    Aug 2012
    I have never checked. Every boat I have owned has done this (non-moomba as well).
    I figured it was the "norm".
    My 2013 had to be one of the very first. It was the first my dealer was able to get, and we are fairly close to the factory.
    Nate
    2008 XLV GG (sold)
    2013 LSV
    Sep 2005
    Claytor Lake, VA
    Also make sure the vent hose isn't kinked. It's a seperate small hose that runs from the gas tank to the filler neck unit.
    2005 Mobius LSV
