Results 1 to 4 of 4
    May 2013
    Default Found a less expensive Fulton F2 adapter plate.
    My boat came with a Fulton F2 jack, but it wasn't installed. I just couldn't stomach the adapter plates I was finding as the least expensive one I found was $76 shipped. I was all set to make my own when I came across this one on e-trailer:
    http://www.etrailer.com/Accessories-...n/F500320.html
    Only $28 + $7 value shipping. I can live with that.
    2008 Moomba Mobius XLV. Monster Cargo Bimini, and more mods to come...
    Tow Rig: 2009 Honda Ridgeline RTL (wife's rig) Other money pits include:1998 BMW M3 Cabriolet, 2000 Jeep Wrangler rock crawler), 2002 Audi S6 Avant, 2005 Kawasaki ZX-6R 636.
    Mar 2014
    Park City, Utah
    you should know by now, if it says boat, trailer or marine anywhere on the packaging the price is at least double.
    2004 Stingray 190LS - Sold
    2013 RAM 2500 Diesel - Tow Rig
    May 2013
    Picture of the actual adapter:
    May 2013
    Install was super easy.
    1) throw away bolt and spacer from OEM jack.
    2) mount plate with supplied bolt (I put some anti seize on there)
    3) Mount Jack to adapter plate using supplied hardware (the adapter plate is threaded so you don't need nuts)
    Adapter mounted:
    Jack mounted:
    (note, the jack has adjustability as the swivel part can slide up or down on the aluminum outer shaft. to adjust it, you loosen BOTH bolts on the jack's swivel piece and slide it up or down. I have the jack in the factory spot which allows it to go more lower than higher...)
