Results 11 to 20 of 21
    Salt Lake City, Utah
    thanks guys, just ordered a T handle rope. We'll see how it works.
    Scott
    May 2013
    Lake Anna, VA
    When people see the t handle they think they can't hold it. It really isn't much different. I have large hands and can wrap all but my pinkies around it. Better than getting your arm stuck in something. If you only offer the T or the knotted rope that is what they learn on.
    2007 XLV Gravity Games
    1,100 in each rear locker
    1,180 in front
    Fresh Air Exhaust
    SuckG8
    Bunch of other crap
    I have a Proline T handle that very rarely ever gets used in the last 2-3yrs.
    Braided one myself with thicker tube rope and an old ski rope handle and love it. It is thick enough that no one even thinks of making the mistake of coiling it up a bunch around their hand. (yes, she got yelled at for that little loop she's holding)
    I noticed in your pic that you just have the rope attached to the cleat -- is there any danger in bending those from the weight of the pull? We have used the tower or the pylon when surfing but never thought to use the cleat....
    Mike
    that's a good way to get newbies off to the side out of the whitewash, but could be some issues with larger riders.
    Another solution can be found at wake9.com: the nubbin'
    http://store.wake9.com/gear/nubbin
    What do you need this for? When new people learn to wakesurf one of the hardest issues for them is the whitewash behind the middle of the boat. The surf nubbin' is a special strap that allows you to connect the rope to the top corner of the tower on the side of the surfer. A special wakesurf tower mount that helps pull the surfer away from the whitewash and into the smooth flats on the side of the boat. We have been through a few prototypes, and this version works perfect, is cheap, and easy to install on all tube towers
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    That's a good idea, I had never thought about that. I just try to maneuver the boat so that the rider is already outside the wake area before starting and if they get caught back in the whitewash they just have to deal with it.
    Mike
    Default Re: What kind of rope to buy?
    Same here, just start them on the side and go slow 3-4 mph until they're outside the wave..
    I'd think having the rope on the cleat would be harder to get up, with the rope on the tower it gives a higher angle so you can pull yourself upward..
    2006 Moomba Mobius LSV
    May 2013
    I guess I'm in the minority. I think that the T-handle is annoying and so do most the people that have surfed behind my boat. I find that when I used the T-handle, that I'd still hold onto it with both of my hands and what would happen is that one hand would get mashed under the other hand.
    I did like the thickness and knots though. I got the body glove one and it was significantly the best deal.
    This was the best price IIRC, it's who I ordered from.
    http://www.jmsonline.net/body-glove-...bgw-bg1208.htm
    My first wakesurf board was a used Hyperlite broadcast and they sold it to me with an Accurate rope with the small handle. That's what I use exclusively now. Looks like this:
    I think that the thicker rope with knots, but then having the small handle would be a great option.
    The reason why I use the Accurate one now is because I get up and as soon as the PP has the wake at the right speed, I'm tossing it in.
    When I was learning, I really needed the thickness/knots to get myself in the right spot. But now that I have the wave more dialed and I'm solid, I don't want it or need it and only want a comfy small handle to get up with. And hey, I've only hit my wife in the back with it once so far!
    We always pull from the tower. It seems like both wake surf ropes I have are sized with that in mind. They're both almost the perfect length to get someone in the pocket and ride there with the rope only in the left hand (regular side).
    I only do that with the kids from the cleat. We found that from the pylon when they'd pop up they'd stay right behind the boat to get situated or get their courage up for a little bit, whatever. Then getting them down into the wave was the problem - and they were either scared to death to even try dropping in or would go for it and wipe out big time.
    Same as you, we started to just pull them slower with whitewash and not get up to speed and form the wave until they were off to the side and that helped some. Can't just toss the rope to the other side of the wave though when pulling from the cleat - it tends to bounce back to the surf side and mess up the rider.
    I've never had much luck pulling surf from the tower - rope ends up being way too short (but my tower doesn't arch back as far as some).
    Other thing I didn't care for about the Proline T handle is that the nice, thick braided part in front of the handle is too short. By the time a rider would pop up and pull themselves forward a little they were holding onto the skinny rope.
    May 2013
    If it were me, I'd just add a length of line. I've got a couple lengths of line that I've pulled off some of my wakeboard ropes that I never use. I've been wakeboarding at 60' so one of those sections would be easy enough to add to a surf rope. The body glove t-handle rope is thick/braided/knots pretty much the entire thing, so it'd be good for avoiding the other issue you spoke of.
    After reading this, I am thinking of turning my t-handle from body glove into a triangle. I am sure I could pull it off without too much effort.
    If we ever hook up and get out on the water together, I'd be happy to let you try either of my surf lines or any of my (3) surf boards.
    I'll be out on the Columbia today! Woot!!!!! Look for the black and white Supra with the "stormtrooper" theme. That's me!
    Jul 2013
    Cedar Falls, IA
    You might appreciate http://www.youtube.com/watch?v=_SEBrcU4z2A
    2013 Moomba Mojo 2.5
    2012 Ford F150 Ecoboost
