Results 1 to 8 of 8
    Feb 2010
    Canton, Ga / Lake Lanier
    Default Boatmate trailer brakes problem
    Hey guys, I was wondering if any of you know what size bolt I need to reattach one of the brake lines to the left trailer side wheel brake. I walked by it the other day and saw that something was hanging. Got under there and it was the brake line. Here are two pics to help describe what I'm talking about better:
    Left:
    Right:
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Feb 2010
    BTW this is a single axle trailer 2010/2011
    Tow Rig:
    That is a special Banjo bolt that the fluid actually runs through. Since you're going to have to bleed the brakes anyway, you may want to just take the other one off and bring it in with you as a sample.
    2001 MobiusV
    Mar 2008
    Default Re: Boatmate trailer brakes problem
    Yup, exactly what he said. Most auto parts stores will have it, if not a brake shop will.
    PWI as usual...
    May 2003
    south east michigan
    Make sure you get the copper washers that go on each side of the square metal block.
    jy
    Jul 2013
    Massachusetts
    A note on the copper washers, I just replaced a broken brake line on my single axle trailer. I went to three diffrent auto parts retailers and was unable to find that size washer. I then went to a brake shop and was told the washer seems to be a custom size as he had never seen one like it before. Now I'm not a car guy by any means, but I thought it strange I couldn't find the proper size anywhere I looked. I ended up ordering the parts from www.boatmateparts.com. Stupid little washers cost $4/each. If you have trouble finding the right size bolt, I would email Jerry at boatmate.
    Jr.
    '08 Outback V
    Feb 2010
    Quote Originally Posted by jyj1189 View Post
    Thanks, I will do that. Do you happen to have his e-mail address?
    Tow Rig:
    Jul 2013
    Massachusetts
    jerry@boatmatetrailers.com He was very helpful with sending part numbers for items that can't be found on the parts site.
    Good Luck
    Jr.
    '08 Outback V
