Thread: Nav lights
    May 2012
    Default Nav lights
    Any advice on changing the bulbs in the nav lights? (Red&green on the bow).
    Oct 2005
    Durham, NC
    I had broken the housing on mine, so I had to replace the entire thing. It is in multiple pieces and was not very intuitive to get apart. It may depend on what boat you have. My 2001 Outback replacement was the Attwood Quasar. The installation instructions are available on their website and will give you some insight into how to get inside to the bulbs. Good luck.
    Brian Roberts
    2001 Outback DD
    Aug 2010
    Acworth, GA
    Quote Originally Posted by thomasob View Post
    What year boat do you have?
    Mine has a tiny set screw that needs removed then the housing and lens pops off, with some force applied. Mine takes those whacked looking bulbs with pointed caps on each end like this
    http://www.go2marine.com/product/161...ps-529102.html
    Edit: If I remember correctly I think I had to twist it some for it to come off. Can't recall which direction, probably counter clockwise, but just guessing...
    Kraig - 2010 Outback V
    Aug 2011
    Newnan, GA
    Yep, remove the set screw to take the chrome piece off and then twist the red/green lens.
    2011 Moomba LSV
    May 2012
    Quote Originally Posted by yz 2smoke View Post
    I have 2006 Outback V
    Thanks for the input, I was close but got reluctant to get too aggresive with the lens cap. Will try again and maybe apray a little oil in there to see if it will come loose.
