Results 11 to 17 of 17
    Richmond, TX
    Default ***On water - wake plate issue***
    There is only one ram or cylinder from the hull to the plate.
    Current: 2010 LSV
    Previous: 2007 Outback
    You have an electrical actuator. Did you confirm the plate isn't moving or were you only going by what the gauge said?
    2015 Supra SG
    Richmond, TX
    Confirmed it wasn't moving.
    Being electric, I have no idea why it moved while the boat was listed, yet did not move as soon as bags were emptied.
    I don't mind buying a new cylinder and just replacing it, but I really would like to know what the root cause is.
    Current: 2010 LSV
    Could be loose wires on the switch. I would start there then test voltage at the switch and the actuator.
    Richmond, TX
    Boat's back at storage, I didn't get a chance yet to dive into it.
    I'll check the wiring, but I'm still confused as to why the listing seemed to correct the problem. I can't imagine it's just coincidence, because the plate was used quite a bit throughout the day and worked flawlessly while listing, but as soon as everything was level again it didn't work. Still made noise when lever was moved "down" (although the plate was already down), yet made no noise at all when lever was moved up.
    Current: 2010 LSV
    Sugar Land, TX
    I seem to remember somebody having an issue with the switch on the steering wheel. Contact issue maybe? Sorry I can't remember exactly what it was, but it was definitely the switch, not the actuator.
    2011 Mobius LSV
    Ron
    Oct 2008
    Central, Arkansas
    You can cut the problem in half to isolate. Find the connector by tracing the wire back from the actuator. Should be 2 wires black/white, you can take the wires directly to a battery and it should move the actuator. Reverse the polarity and it should go the other way.
