Results 11 to 20 of 35
    Aug 2008
    Hilliard, Ohio
    Patrick, when you say the size, do you mean the measurements? and what is CNC? I can get the measurements for you tonight no problem.
    Correct size = measurements, then I can draw in CAD. A CNC is a computer controlled cutter. Think of a milling machine with a large flat bed and a hand router moving in XY and Z
    Salt Lake City, Utah
    Ok, here are the measurements, I hope this is what you need. Let me know if you have any questions. I would cut on the side of being a tiny bit big so you can trim/sand it down to fit.
    Scott
    That came out great! I want one! Patrick if you can cut some out I will gladly pay you!
    Scott, where can I find that cap rail???
    Sent from my iPhone
    David, I actually have an extra piece I am happy to send you. Pm me your info and I will mail it out.
    Scott
    Aug 2008
    Hilliard, Ohio
    Sent from my iPhone
    From a quick glance I can get 9 or 11 out of a 4'X8' sheet of plastic. Let me call my sheet supplier and get in on order. David and I get the first 2 that means the others are up for grabs. Ill figure out cost later.
    Quote Originally Posted by patrick232 View Post
    Awesome! This will be great in November and March!
    Sent from my iPhone
    May 2013
    Lake Anna, VA
    Wow that looks great. I will have to put one together for mine but much shorter.
    That end cap material can be found at http://www.mcmaster.com/#standard-plastic-trim/=oqxrhf
    Check out the Style 2. If that doesn't do it mcmaster.com usally has something there you just have to look. 25ft. min but if you are making them for others that won't matter.
    2007 XLV Gravity Games
    1,100 in each rear locker
    1,180 in front
    Fresh Air Exhaust
    SuckG8
    Bunch of other crap
    Patrick,
    I'd be interested in one depending on cost. Please let me know and thanks for doing this.
    Scott,
    Looks great, nice work!
    Feb 2011
    I'm in for one as well
    2009 LSV Liquid Force Edition
    - Gravity III
    - Z5 Rack
    - ACME 1847
    - Polk MM6501UM - Kicker IX500.4
    - Kicker CompVX 12" - Kicker IX1000.1
    - Pair Wetsounds Rev 10s - JL Audio HD750/1
    - RGB LEDs
    used it tonight up at the lake and it works great. No movement at all and no air coming through. It seals off really nice.
    Scott
