    Mar 2012
    South Carolina
    Default help me with some pulley info so I can hang my z5
    I'm in need of some info from you much more knowledgeable folks than I am. Here's the purpose: I want to hang my z5 rack from my garage ceiling, and I want it to be upside so it can go fairly flush. I want to get this thing out of the way and I have tall ceilings that will help with this.
    I'd like to find some cheap but sturdy pulleys and anchors for this job but I'm not sure what to look for or get. The first question I have is how to anchor the pulleys into the stud of the ceiling. I had looked at HD the other day just for sh*ts and giggles and I found one that "could" work maxing out at 125 lbs. or so. It had a circular "fast eye hook" if thats what you call it. It was a Lehigh Zinc plated 2 inch pulley. I'm not sure how to anchor it in the ceiling though. I want to have a 3 point system, so any ideas and if you can provide links or names of hardware I should look for I'd appreciate it.
    Justin
    I use 2 of these to hold my Thule bullet box to the ceiling. You could use three, no problem just an eye hook in the ceiling stud.
    http://www.lowes.com/pd_54992-72607-...7C1&facetInfo=
    I use one of these to lift our 2 person kayak up & out of the way
    http://www.harborfreight.com/bicycle-lift-95803.html
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Mar 2008
    I just have 2 bike hooks and hang it right side up. Cheap and easy. Hangs above the garage door when its open.
    PWI as usual...
    Search the Jeep sites. Lots of guys on there store their hard tops up on the ceiling. I know my brother was describing some pulley process but I couldn't picture it. Good luck!
    Sep 2010
    Lake wallenpaupack PA
    Dicks sells pulley systems to hoist canoes up to the ceiling. The were pretty too
    Mar 2012
    South Carolina
