    Mar 2013
    Default Led transom light
    Has any tried these from superbright LEDs
    2013 Moomba LSV
    2013 LSV
    2006 outback DD sold
    2004 Stingray 180LX sold
    Dec 2012
    NW Minnesota
    I priced these out to go on the boat we have on order. But the guy I talked to said they had to remain below the water line???? I don't understand how this could be.... that would mean that they cannot be used when the boat is on step. I need to do some more research about this. let me know if you find out any good info.
    Quote Originally Posted by TJockey View Post
    that would mean that they cannot be used when the boat is on step. .
    I have no idea what this means?
    However, the guy is correct. These lights mount on the transom, under the swim platform & below the waterline. They are meant to light up the water behind the boat.
    2015 Supra SG
    Default Re: Led transom light
    On plane.. Probably was trying to say not in motion, may be against the law where he is?
    2006 Moomba Mobius LSV
    I've been running behind a buddy with these at night on a plane (on step?) and it was blinding. His were white and mounted off to the sides which probably didn't help. Centered, angled down or mounted way low is the only way to go.
    2001 MobiusV
    Mar 2013
    Do they light up the water good,I was thinking of putting 2 on my transom in blue
    2013 LSV
    Oct 2008
    Sylvan Lake, Alberta
    Quote Originally Posted by Sharpshooter View Post
    I have two green ones on the Mojo and they light up lots. Looks great underway as well as just sitting still.
    2012 Mojo
    Mar 2013
    Thanks, now I have to spend another 200 bucks on LEDs, but hey whatever looks cool right
    2013 Moomba LSV
    2013 LSV
    Mar 2013
    Quote Originally Posted by gisepi View Post
    Do you have any night time pics
    2013 Moomba LSV
    2013 LSV
    Dec 2012
    NW Minnesota
    On step is a term we have always used to mean "on plane". I guess going fast enough so that the the entire hull has"risen" and is riding on and not through the water. Meaning that the transom has no water against it. When a boat is moving at a cruising speed, the waterline is at the base or the bottom of the transom.....there is no waterline on the transom at cruising speed. that was my confusion, if the lights must be below the waterline than how can they be used at cruising speed if there is no waterline at that speed?
