Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Dec 2012
    Trois-Rivieres, Quebec
    Default OZ HD tower on 2014 Mondo
    Anyone has seen the thread below?
    http://www.moomba.com/msgboard/showt...n-lowered-down
    Does anyone has tried that on a Mondo? Is it the same? I will have to adjust the cable for sure if I want to fit the boat in my garage...
    Sampp
    2014 Mondo
    Could be worst
    From nice Québec..
    Aug 2008
    Hilliard, Ohio
    Sampp, Just had some time to check out my Mondo on the trailer.
    From the factory the screw looks to have adjustment of about an 1" or so.
    Currently my tower is at 84.5" but the jack is high. I should have more time this week to adjust and get her under the 83" I hope. The problem I have is the fixed racks on the upper points will have to come off, not sure if I will order a second set of swivel or what at this point.
    Dec 2012
    Quote Originally Posted by patrick232 View Post
    I think mine is up to 7'3" with the wake tow on top of the tower. I didn't have à l'éveil when I to ok the measure.
    I'm thinking about butine some smaller wheel and tire and swap just before backing the boat in the garage.
    My new boat is still at the dealer, so not that easy to make some other measures...
    Sampp
    2014 Mondo
    Could be worst
    From nice Québec..
    Aug 2008
    Hilliard, Ohio
    I did not look at the wake tow point, will have to look at that too.
    Aug 2008
    Hilliard, Ohio
    It won't go in the garage due to the tower tow point. Might look at dropping the trailer closer to the tires. Think there was a how to on it.
    Oct 2008
    Central, Arkansas
    Quote Originally Posted by Sampp1963 View Post
    Should be the same, you can lower quite a bite. I am pretty sure it is only one size OZ tower ('14) that is used for the all boats. That being said you will have different lowering levels between a Mojo and a Mondo since the cabin area is a little smaller on the Mondo.
    What axles do you have on the trailer, torsion or springs?
    LSV, Mondo & Mojo all have the larger diameter tower (know as HD in 2013) while the Outback V still uses the smaller diameter tower.
    2015 Supra SG
    Jul 2013
    Cedar Falls, IA
    If you physically measure the OD of the towers, what are the measurements of the OZ and OZ HD? I'm getting 1.895" with calipers on my tower.
    2013 Moomba Mojo 2.5
    2012 Ford F150 Ecoboost
    Not positive but HD is over 2inch.
    From your profile pictures you have the standard tower diameter.
    I think standard Oz is 1 7/8"
    2015 Supra SG
