Results 1 to 5 of 5
    Apr 2013
    Default fix cracked, chipped surf board
    Hi there, Just wondering what you guys use to fix cracked or chipped surf boards? I've got a cracked Koal board that I should fix before the season starts...
    2013 Moomba LSV
    2013 Moomba Outback V (Sold)
    2002 Mastercraft X-5
    Wolfeman is the master at fixing these. I think he uses a two part epoxy.
    Yep, we've had to fix a few. Some of the board mcg offer repair kits so colors match (or come close) and I've also used 5 min epoxy. Thin layers and ultra fine sandpaper can help make the repair less noticeable.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Apr 2013
    k, sounds good... I'll try that! Thanks guys!!
    2013 Moomba LSV
    Sep 2012
    Tucson, Az
    I tried this phix doctor last year and it worked great. It cures using uv from the sun. http://phixdoctor.net
    Bets the old days of two part resin when fixing my surf board. Check it out
    2007 Moomba LSV
