Results 1 to 9 of 9
    Feb 2012
    Murrieta, CA (SoCal)
    Default Attached oil drain tube too big and not long enough?
    I'm getting ready for my first oil change since I've owned my 2002 OB LSV. I got my hands on the drain line, but it doesn't fit out the bilge plug hole with the cap on (hex cap is just a little too big). Also, it doesn't look long enough to reach past the cavitation plate.
    Am I missing something easy? Thanks.
    - John
    2002 Outback LSV
    You suck it out of that tube, or at least that's what I do. I have a pela 6000 oil extractor that has a small tube that goes down inside the tube that you speak of and then I suck the oil out.
    Sent from my iPhone
    Feb 2011
    Skiatook Lake
    http://www.westmarine.com/oil-change...uart--11047123
    On my 2010 the hose would fit through the drain hole but I have an extractor now and its much easier and faster than trying to get the hose down there.
    4-5 pumps on the handle creates a vacuum and oil is empty in about a minute or so.
    Yours is much faster than mine!
    Sent from my iPhone
    Mar 2012
    Spring, Texas
    Mine too. It takes at least 2 beers to empty mine.
    Wetsounds Rev 10's
    XS-650's
    Syn 6
    Syn 4
    WS-420
    Mar 2012
    South Carolina
    MityVac 7201! Best investment. $69 on amazon.
    Feb 2012
    Thanks for the input everyone.
    - John
    2002 Outback LSV
    Feb 2011
    Skiatook Lake
    Sent from my iPhone
    I hook up fake a lake and bring up to op temp, take oil fill cap off and put the hose of pump over the oil drain tube and pump it 4-5 times. It creates very strong vacuum. I've noticed its considerably slower if oil is cold or if I forget to take the fill cap off.
    Feb 2012
    I ended up sucking the oil out of the engine drain line by coupling it to the suction tube of a little lawnmower oil extractor (3L I think). I did fish it through the bilge plug hole so I could avoid spilling anything inside the boat. Stuck a zip lock back around the filter once it was loose and spun it off inside the bag to avoid spills there too. I was 100% spill free too until my 5yo daughter asked to help.
    - John
    2002 Outback LSV
