Results 1 to 8 of 8
    Dec 2012
    Trois-Rivieres, Quebec
    Default How cold can the water be?
    Anyone knows how cold the water can be for a raw water cooled engine?
    My new Mondo will be delivered in late May......and the water will be around 45f .....
    I asked indmar, but didn't get any feed back.
    Sampp
    2014 Mondo
    Could be worst
    From nice Québec..
    Tuscaloosa, Alabama
    Doesn't matter. It has a thermostat
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    As long as the water isn't frozen you can go boating. The impeller is the only part that requires water to not self destruct, and it is before the thermostat.
    If the engine can't get to operating temp the only thing that happens is it runs in cold mode and that means Rich fuel mixtures causing you to use more fuel.
    As long as its not frozen over.
    Nov 2009
    Nebraska
    I was in 40 degree water a week ago.
    2010 Moomba LSV
    Jul 2011
    Murrieta, CA
    If not frozen enjoy the new Mondo.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Dec 2012
    Thanks all.....
    I knew about the thermostat, but I was still a bit worried about the low temperature..
    Sampp
    2014 Mondo
    Could be worst
    From nice Québec..
    Jan 2011
    Western PA
    You'd have to worry about air temps if you are going before they stay above 32 deg F.
    2004 Supra 22 Launch SSV
    325 Indmar Assault 320 HP
    "One more hour"
