Results 1 to 5 of 5
    Jun 2009
    South West Colorado
    Default How to clean water strainer?
    Hey guys, I have an 08 lsv and I have the raw water strainer. When I bought the boat new in 09, the strainer was clear and I could see what was going through it easily. 5 years later and it is real cloudy. I can see into it if I look closely but I would like it to be clear again.
    What would you use to achieve this? I was thinking about CLR or something similar. Thoughts?
    That or simple green,
    Jul 2011
    Murrieta, CA
    Let it sit with a vinegar solution for a few hours and then brush out.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Jun 2009
    South West Colorado
    Thanks guys.
    Sugar Land, TX
    You could try a little oxy clean, the laundry detergent, in there with warm water for an hour or so too. I used to use that to clean our brewing equipment.
    2011 Mobius LSV
    Ron
