Results 1 to 10 of 12
    Jan 2013
    Northeast, PA
    Default launching Boat questions
    I been having trouble launching and also getting the boat back on the trailer ave looking for recommendations. When i launch the boat the bow is getting stuck on the bow stop roller.when getting yhe boat back on the trailer the bow hits the bow stop roller and i struggle to get the bow over the roller. I followed the manual which says to have the fenders a couple inches under water. I am not sure if the hitch is too high or low or something else I am doing. Any suggestions?
    2007 Moomba Outback V
    Sounds like you are backing the trailer too deep.
    Jan 2013
    Northeast, PA
    I have tried not backing as far but then struggle to get the boat off the trailer
    Jun 2009
    South West Colorado
    How steep of a ramp are you launching on? On the lakes I use, I put the boat trailer fenders 1" under the water and it is perfect. Sounds like your ramp is steeper than what I use.
    Default Re: launching Boat questions
    Sucks, it's probably the ramp angel. On my old ramp you had to power load it( insert power loading complaints, bla bla, bla).
    Just leave the trailer a little higher out of the water and then use a little throttle to push it up and crank pulley at the same time..
    2006 Moomba Mobius LSV
    Tuscaloosa, Alabama
    Fenders under water to launch. Fenders tops out of water to load. Thats how I do it
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    May 2014
    Clermont, Fl
    "Fenders under water to launch. Fenders tops out of water to load."
    good rule of thumb jmb!
    Exactly how I do it. To launch boat, truck driver backs boat down ramp far enough where he hits the brakes and the boat slides into the water.
    Jan 2013
    Northeast, PA
    I tried using a lower hitch which seemed to help a little. Never really took notice to the angel of the launch ramp until today. I will have to try the fenders at the top of the water tomorrow morning. If only there was a lake community near by, I would just buy a new home on the lake, that would solve that problem quickly..... although, I may miss watching all the Wall's trying back their trailers in and out of the water. On second thought, I wouldn't miss it at all.
    Tuscaloosa, Alabama
    Quote Originally Posted by Gabbyg88 View Post
    That would solve the problem.
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Jan 2013
    Northeast, PA
    Great advise on getting boat back up on trailer. Top of fenders at the surface of the water worked great. Bow came up over the bow roller and I had the wife gas it a little bit and done .. only problem the trailer winch broke.
