Results 1 to 10 of 20
    Rice Lake, Ontario
    Default 06 LSV bildge not working, not sure how to remove.
    Hey everyone. Been a while since i was on the forums.
    06 Möbius LSV
    Shaft was leaking bad when I came in yesterday and I didn't notice. It started to rain 4 hours later so I went to cover boat. There was about 4-6 inches of water in hull. Hit the bildge switch and nothing. No light. Hit the reset light and light came on but no bildge.
    Used the pump for my ballast bags to drain and tightened the shaft. Stopped the water for now.
    But the bildge won't come on.
    Is there another fuse beside the resetable one at switch?
    If I need to replace the bildge, how do I remove it? How do I disconnect it from the hull?
    2006 Moomba Mobius LSV
    Lake: Rice lake, Ontario
    Stereo: Kenwood KMR-D562BT
    Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"
    If you're from the area and want to surf, send me a PM!
    Rice Lake, Ontario
    This appears direct replacement. Do I need to cut wires or will it just be plug and play? Can't see if there is a harness included.
    http://www.skidim.com/prodinfo.asp?number=6031726
    Any discounts available at skidim?
    Default Re: 06 LSV bildge not working, not sure how to remove.
    Does it turn on when you twist the knob on the side? Usually it gets stuck and doesn't turn on automatically. Open it and clean it, but it happens a lot with that pump style. I add a second pump to solve that..
    Rice Lake, Ontario
    Turned the knob. Just soundes like a flap. Never turned on.
    Pop it out of its mount base using a flat head screw driver or strong fingers and see if impeller is jammed, carpet fibers sometimes get in there. Mine broke and I got it at Wally World, and swapped the pumps into the mounts and spliced the power cords.
    http://www.walmart.com/ip/Sahara-500...2-VDC/11071160
    Rice Lake, Ontario
    does the walmart or skidim come with the harness like below?
    Rice Lake, Ontario
    I *may* have found one locally at Canadian Tire.. I will check to see if they have it in stock tomorrow.
    http://www.canadiantire.ca/en/pdp/au...-0793514p.html
    Rice Lake, Ontario
    Quote Originally Posted by spyder View Post
    had it in stock, $62.. doesn't come with a wire hardness though so i'll have to splice... booo.
    May 2013
    Make sure the circuit board is plugged into the back of the switch. Mine comes undone when tubing really hard. I have to reach from the back along the gunnel to push it back on. The auto switch works but not manual when this happens
    Rice Lake, Ontario
    Quote Originally Posted by cornrickey View Post
    would that explain shorts? hrmm.. but manual and auto are not working on mine,.
    we were tubing and hit a few good bumps.
