Results 1 to 5 of 5
    Default No fuel when wake surfing
    Hey,
    I have a 2000 Moomba Outback LS when wake surfing I'm regular footed, and when I run it below half a tank I'm no longer pulling fuel and run the lines dry. Has anyone run into this problem before? If so what did you do to fix it?
    Nov 2009
    Gatineau, Quebec
    The fuel line in the tank is probably rotten or cracked, pull it out to see
    2012 Mobius LSV
    05 Outback LS SOLD
    Check the lines and filter, all good. Any other ideas? Only time it's an issue is as listed above....
    Nov 2009
    Gatineau, Quebec
    Well the only other thing I can see is , when your tank is below 1/2 a tank and now you're listing your boat on its side,the fuel pickup in the tank is no longer in the fuel . Keep the tank full for surfing .
    Can you run to 1/4 tank and bellow skiing with the boat not listed ?
    2012 Mobius LSV
    05 Outback LS SOLD
    Papou, I can ride all day wake boarding no issues. It's only when wake surfing. So I just assumed it was the fuel pick up as well. Hoped that someone could tell me otherwise! But doesn't seem to be the case.
