    Jan 2005
    Default Tach goes haywire
    Anyone have this happen to them? When crusing at about 2,500 RPMS, tach starts bouncing around up to 4K. When you tap on it, it goes back to normal for a few seconds then starts again. Probably a loose wire or something, but havent had time to check it out. Just wanted to see if anyone had any pointers.
    Thanks,
    Phillip
    Oh, its a 2005 Mobuis LS.
    Jun 2003
    New Orleans, LA
    Default Replying to Topic 'Tach goes haywire'
    any other recent problems with the boat...any battery problems?
    have you had to jump start it recently, or had a dead battery, or charging problems?
    Sound like it could be a voltage regulator problem on the alternator, or somehow the tach got shorted. If all else fails, replace the tach.
    ps
    Patrick S.
    Mar 2006
    Chapin, SC
    My Tach fried after doing that because the ignition wire behind the key was lose. But also my boat was trying to shut off and then refire because that wire was not completely disconected. If your boat is not running bad then I would not know what shot the tach like that. Good Luck
    I mess with Texas
    Mar 2006
    Chapin, SC
    I mess with Texas
  1. Tach problem
    By rshea99 in forum Service & Repair
    Last Post: 07-17-2007, 12:52 PM
  2. Tach not working
    By 98outback in forum Service & Repair
    Last Post: 05-12-2007, 07:00 AM
  3. Tach inop on my 99 Outback
    By gdyupngo in forum Service & Repair
    Last Post: 08-12-2005, 09:47 PM
  4. speedo's leaking tach n hour meter dead
    By DOCDRS in forum Service & Repair
    Last Post: 07-06-2005, 10:10 PM
  5. Trouble With Tach
    By Bobby in forum Service & Repair
    Last Post: 03-03-2003, 11:45 PM
