Results 1 to 9 of 9
    May 2014
    Clermont, Fl
    Default fused power/ground distribution block
    does anyone know of a fused power/ground distribution block where....
    one 1/0 awg positive cable feeds it and it somehow splits off into two separate fuses
    and
    it also has an input for 1/0 gnd cable that feeds two amps?
    I have a JL Marine amp and a Harpoon amp and they both require different fuse ratings
    JL M400/4 = 40A
    Harpoon = 250W
    Exile does sell those types of blocks. I can't recall the brand. Millerda has a thread with pics of them.
    Positive is a 4 out with desperate fuses.
    Negative is a 4 out no fuses.
    I have an older LED block with positive and negative but I don't think they make them any longer
    Nov 2009
    This is what you need for power just order the appropriate fuses.
    http://www.sonicelectronix.com/item_...2FDB-148M.html
    and ground.
    http://www.sonicelectronix.com/item_...12DB-1144.html
    -Mark
    "Hey you only live once"
    May 2014
    Clermont, Fl
    Thanks Mark. If I can't find what I'm looking for, I may go that route.
    I'm really wanting a combined fused/gnd block - just for less clutter above the batteries and simplicity sake.
    Vicksburg, MI
    Quote Originally Posted by slipperyrockTKE300 View Post
    I think this is what you are looking for.
    http://www.ebay.com/itm/TSpec-V12DB1...ht_1925wt_1238
    It has 1/0 power and ground coming in and 4 gauge power and ground going out.
    Here is the link to the T-Spec catalog.
    http://www.tspeconline.com/index.php...page=page&id=7
    I think T-Spec used to be Tsunami.
    Joe
    2014 LSV
    2010 Outback V - Sold
    Vicksburg, MI
    The T-Spec part number is V12DB-14PN
    Joe
    2014 LSV
    and
    JL M400/4 = 40A
    Harpoon = 250W
    The Harpoon only has 80A combined internal fusing and would normally only consume about 50A with both chnls @ 2 ohm. Does the JL have its own internal fusing? If your calculations are done correctly, that secondary fusing is redundant and not always needed. But you absolutely need circuit protection on the main trunk line.
    If you want to use the extra fusing = Metra T-Spec V12DB14PM
    Jul 2013
    Cedar Falls, IA
    As Mike mentioned, Exile carries the Tspec stuff. Brian has some pretty nice kits that include Tspec wire, blocks and fuses... pretty good deal on great quality stuff.
    2013 Moomba Mojo 2.5
    2012 Ford F150 Ecoboost
    May 2014
    Clermont, Fl
    Thanks for all the great replies.
    All I'm looking for is a way to eliminate one main trunk line off the battery.
    I now have one for the JL fuse and one for the Harpoon fuse.
    Both positives and the ground go to the same distribution block.
