    Apr 2006
    Cumming, GA
    Default Fat Sac Placement?
    I have a 99 Mobius and wanted to know the best place for 500# Fat Sac. I see some people put it in the rear locker and some say not to because of the gas tank. Anyone have any input?
    Mar 2003
    Dearborn, Michigan
    Default Replying to Topic 'Fat Sac Placement?'
    Do not place the sac in the rear storage compartment without adding a support structure over the PLASTIC fuel cell. I think most people are putting a sac on both sides of the engine or under the rear seat. Does your 99 have the plastic tank under the rear seat? We had a 2003 Outback LS that came with the tank regardless of how you ordered the boat (with or without factory ballast) You should also look at adding a sac in the ski locker if your boat has one. Try to have a 60 / 40 weight distribution from back to front.
    Jeff
    Dearborn, MI
    Apr 2006
    Cumming, GA
    My backseat is all fiberglass underneath the cushion. It doesnt convert to a sun pad like the Outback. And I dont have a ski locker. Maybe a tube sac in the walk thru area?
    Mar 2003
    Dearborn, Michigan
    Cam,
    Looks like that's your only option. There are guys on this board who have added ballast to their rear lockers after adding a support structure. If you do a search I'm sure you will find something. Good luck.
    Jeff
    Dearborn, MI
  1. Subwoofer Placement Question
    By cab13367 in forum Audio & Electrical
    Last Post: 10-14-2009, 03:21 PM
  2. Radio placement in a 1997 boomerang
    By msbarbho in forum Boat Owners
    Last Post: 05-17-2007, 10:08 PM
  3. sub placement
    By lsvtom in forum General Chat
    Last Post: 03-05-2006, 11:45 PM
  4. Mirror Placement
    By silverski in forum General Chat
    Last Post: 05-19-2005, 10:23 AM
