I've only had my V for two weeks, but I think I need more ballast, expecially for surfing. I have the gravity III system right now. From what I've read, the backs are 250 each and the front is 600. Is this right? I'm thinking about getting the 750 pound Pro X for each side of the back. Will I need to add more to the front? Is there room to put a larger bag under the floor or will I have to set something on top?
Thanks in advance for any options,
Brad
Results 1 to 10 of 14
Thread: outback V ballast
06-10-2006, 09:00 PM #1
Junior Member
- Feb 2005
- 27
outback V ballast
06-10-2006, 09:01 PM #2
Junior Member
- Feb 2005
- 27
Replying to Topic 'outback V ballast'
thanks in advance for any opinions, not options.
06-11-2006, 09:48 AM #3
.common misconception on this board (and almost everywhere) is that you need a HUGE wake and a ton of ballast for surfing
I only need to use two 600lb bags
OK, so not a ton, but 1/2 a ton or more.
Now that's funny
06-11-2006, 02:22 PM #4
Senior Member
- Oct 2005
- Central FL
- 791
Not sure the 750 will fit in the v-drive box... look at the v-drive pair of sacs from fly high - 400# each , then - as Ed stated - you only want to weigh down one side, so only fill one of them. Maybe keep a 250# and use it outside the v-drive box - move the rear seat forward and put it on the same side as the 400 - that will give you 650 on one side - if that is not enough to push the corner of that boat in the water - nothing is.
Also remember to adjust the wakeplate up all the way.
-J
p.s. - sorry - I gave an alternative OPTION as well as an OPINION. Guess I don't win the cuppie doll.
06-11-2006, 06:31 PM #5
Junior Member
- Feb 2005
- 27
I just measured the compartments. The 750# sacs won't fit. The 400# will though. I also looked at the sac under the bow. I was told this was 600#, but I don't think its possible. Looks more like the 370# tube sac barefoot intl has on their website. Does anyone know which is right?
06-11-2006, 08:56 PM #6
Junior Member
- Feb 2005
- 27
Joe,
Thanks for the option and opinion. I'm going to call BI tomorrow and see if they caps for the drain and fill for the 250s that I have. I think with the 2 400s in the back while wakeboarding though, I'm going to have to find some way to put more weight in the front.
06-12-2006, 12:18 AM #7
Senior Member
- Oct 2005
- Central FL
- 791
For wakeboarding, your current front sac should be more than enough as well - you can also use the wakeplate to adjust as well.
Try before you spend more $.
-J
06-12-2006, 07:30 PM #8
Junior Member
- Feb 2006
- 4
I believe the front bag is 450#. At least it is in my 06 LSV.
06-12-2006, 09:26 PM #9
Junior Member
- Feb 2005
- 27
Here's what I think I'm going to do. From what I can tell, the bags on either side of the engine are around 275 each. The one under the floor is about 400. I'm going to buy 2 fat bricks (150 pounds each), one for each side of the engine. They should fit in there with the 275 bags fine. So that would give me 850 pounds in the back. I can also move the fat bricks around when I want to surf. I'm going to get a bow sac for the front. I hope to get close to another 400 pounds out of that, so 800 pounds total in the bow. What does everyone think?
Thanks,
Brad
06-13-2006, 12:07 AM #10
Senior Member
- Oct 2005
- Central FL
- 791
...1650 Lbs of ballast later...I've only had my V for two weeks...
I think you need to go enjoy your new boat more !What does everyone think?
-J
outback ballast help
By axel_T in forum Wakeboarding | WakeskatingReplies: 2Last Post: 04-25-2008, 07:07 AM -
Ballast in DD Outback
By danimal365 in forum Wakeboarding | WakeskatingReplies: 12Last Post: 04-20-2008, 08:57 AM -
outback V 07 ballast
By jmvotto in forum General ChatReplies: 7Last Post: 02-27-2008, 02:59 PM -
Ballast for an 06 outback
By csumerall in forum General ChatReplies: 3Last Post: 03-04-2007, 11:15 AM -
Outback factory ballast
By NCSUmoomba in forum Boat OwnersReplies: 4Last Post: 07-03-2006, 11:06 AM
