Results 1 to 6 of 6
    Jan 2006
    Jacksonville, FL
    Default oil and transmission fluid change
    i am fixing to change the oil and transmission fluid in my 98 outback. It has the 5.7 litre carb engine. I have found some post for 99 5.7's but was not sure if this would be the same for me. I am assuming this would take 15w-40 penzoil marine oil and then dexron III for the transmission. Also could someone tell me what oil filter to go with? Thanks
    Mar 2003
    s.e. washington state
    Default Replying to Topic 'oil and transmission fluid change'
    On the transmission it is important not to underfill or overfill so when I change the engine oil I use the old containers to pump the tranny fluid in so that I have an accurate measurement of what was taken out.
    1998 Mobius
    310 HP PCM
    Jan 2006
    Jacksonville, FL
    Thanks. Very helpful idea. Now I just need to make sure I am using the correct fluids and I will be set.
    Mar 2006
    Chapin, SC
    Exactly, several solo cups works for me after pumping it out. Fill each cup to the line and then get the same number of new cups and match... pour it in and your set.
    I mess with Texas
    Aug 2002
    Maryville, Tn.
    You will be fine with the Pennzoil 15W40 oil and the DexronIII tranny fluid. Indmar suggeststs the Pennzoil PZ3 oil filter, however, if not available, have it cross referenced. Brian Raymond
    Jan 2006
    Jacksonville, FL
    Thanks Brian. I will be doing this as soon as I get off work today. Trying to get everything ready for the long weekend.
  1. Transmission Fluid Filter?
    By AaronWhitt82 in forum Service & Repair
    Last Post: 12-13-2007, 01:46 PM
  2. Transmission Fluid
    By kyle_cmu in forum Service & Repair
    Last Post: 07-27-2007, 01:23 AM
  3. Transmission Fluid Change
    By mattjj23 in forum Service & Repair
    Last Post: 09-06-2006, 08:52 AM
  4. Transmission Fluid Change
    By Wesmorgan in forum Service & Repair
    Last Post: 07-25-2005, 02:30 PM
  5. Transmission Fluid Change
    By carsondoc in forum General Chat
    Last Post: 10-06-2003, 03:03 PM
