I have a 2000 outback and it is running like S@#t, Heavy gas smell coming from exhaust, what could cause this,
Results 1 to 10 of 15
Thread: engine running poorly
06-09-2003, 01:25 PM #1
06-09-2003, 09:58 PM #2
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Rich runner
Is the motor a carb. model or fuel injected? How is the boat used, wakeboarding, skiing, or a little of both? If it is a carbureted version, it may be fouled plugs or incorrect float level or ruptured power valve. The carb. is a 4160 Holley. which requires bowl removal for the proper float adj. You may also have gunk build up on the needle and seat valve which control the float level, and let in unmetered fuel, a ruptured power valve will do the same. If you have not changed the plugs in the last 100hrs., or at the beginning of the season, it would be wise to do so. If the motor is fuel inj. you may have a faulty coolant temp. sensor which may tell the engine it is running cool, thus giving it more fuel. Your gauge temp. send. unit is run off of another sensor, so your analog reading may be correct, but the other sensor is telling the motor how to run. Have this checked out by a dealer, they should have you running better in no time. Brian Raymond
06-10-2003, 06:52 AM #3
It is carbed, I changed the plugs, dist. and points, I cleaned the carb pretty good, and ran sea fome through the fuel system, Do you have to jumper the ignition to set the timeing or can you just set it at idle...I have a wierd feeling this is the problem, I am not fluent with holly's so I would take it to the dealer for that but have all the tool to do anything else.
06-10-2003, 10:29 PM #4
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Rich boat
With a points distributor, there is nothing to shunt out for timing issues. Timing should be @ 10deg.BTDC under 850 rpm. It sounds more like a fuel issue than a timing issue, or electrical problem. Brian Raymond
06-12-2003, 07:14 AM #5
oop
Sorry didn't mean points cap and rotor is what I was going for
06-12-2003, 10:52 PM #6
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Rich boat
You may also want to check the choke adj, if it seems to be functioning properly, I would look into a rebuild.Brian Raymond
06-13-2003, 03:34 PM #7
carb
Check the small filters on the Carb. They are located right behind the fuel lines going into the carb (you need to use 2 wrenchs to pull this apart). Mine were totally gummed up so my friend and I tore apart the carb and cleaned it out completely. Had to buy new gaskets which cost like $8.00 and the filters to the carb were about another $8.00. I am just throwing out an idea.
Brian Raymond,
What is the proper idle RPM on a 310HP carb motor (is it 850RPM)? Also what temperture should the motor run at?Richard
2001 Mobius
06-13-2003, 10:15 PM #8
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Carb. setting
The engine(@ operating temp. of 160 deg.) should idle between 700-800rpm., ideal in gear @ idle is 650-700. It is important to have the idle air bleed screws(on the sides of the main metering plate behind the primary bowl) adj. properly. A good reference is to screw them all the way in, and then back them out 2.5 turns. Carbs will differ, if you have a good ear, screw in (one side at a time) until you hear the eng. lower in rpm., then unscrew until the eng. picks up rpm., it will fall off again if you back out to far, just screw in again to max rpm. Repeat on other side. Once this is done, set your idle accordingly. The engine should normally run between 140-175deg. depending on water temp. When shut down and restarted, higher temps may first be noted. If running temps are higher, check trans. cooler on intake side for debris, also check for impellar wear. If temps. are cooler, it may be a thermostat. Brian Raymond
06-14-2003, 10:26 PM #9
Member
- Jun 2003
- 37
Where is temp sensor located?
Where is the temp sensor located? Not the analog one for the engine temp guage, but the one for the injection efi system.
06-14-2003, 11:46 PM #10
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Temp. sensor
The Coolant Temperature Sensor(CTS) is located on the intake manifold above the #1 cyl. It is a 2 wire brass sensor(blk&yel). You can determine if this sensor is faulty by(A) taking the boat to a certified dealer, or (B) taking an ohm reading at running temp. to determine if the sensor may be open or grounded out. Brian Raymond
Engine running rich
By dodes in forum Service & RepairReplies: 3Last Post: 08-26-2005, 11:03 AM -
'01 Mobius running bad
By wforic in forum Service & RepairReplies: 1Last Post: 06-05-2005, 10:47 AM -
Running Rough
By cham783 in forum Service & RepairReplies: 2Last Post: 08-15-2003, 05:08 AM -
Running Hot
By wdf in forum Service & RepairReplies: 1Last Post: 06-26-2003, 10:08 PM -
Carbureated Engine Not Running Right
By ChipB in forum Boat OwnersReplies: 9Last Post: 03-01-2003, 09:59 AM
