Id like to replace my plug wires and distributor. They set I have now has Indmar on them. Anybody replace theirs with a set they got at Napa that wasnt Indmar? Larry from Indmar are you out there?
Thread: Plug wires and distributor
08-24-2006, 11:18 AM #1
Senior Member
- Apr 2005
- Madison, WI
- 198
Jim Hagen
Madison, Wisconsin
facebook.com/signedgewraps
08-24-2006, 11:31 AM #2
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Replying to Topic 'Plug wires and distributor'
I would stay OEM, especially when dealing with electrical and fuel components. By replacing with OEM parts, you can be assured that those items meet all the proper specs. for marine application. Brian Raymond
08-24-2006, 06:22 PM #3
Senior Member
- Aug 2006
- Millington TN
- 142
Once again The Boat Boy speaks the truth. Cheap spark plug wires may not have boots and insulation that will hold up under the extreme conditions that a marine engine is exposed to. Split boots or cracked insulation could allow arcing that could ignite gasoline fumes if you had a fuel leak. The distributor cap must seal tight against the distruibutor body to prevent arcing as well.
LarryLarry Engelbert
Indmar Marine Engines
"Power to the Sport"
08-24-2006, 06:36 PM #4
Senior Member
- Apr 2005
- Madison, WI
- 198
Ok, you convinced me. Thanks guys for the input.
Jim Hagen
Madison, Wisconsin
Which Spark Plug wires from SkiDim??
By AaronWhitt82 in forum Service & RepairReplies: 7Last Post: 03-02-2008, 09:07 PM -
Expansion Plug
By narcosis in forum Service & RepairReplies: 3Last Post: 03-21-2007, 06:18 PM -
Pulling the plug on an LSV
By helix_rider in forum General ChatReplies: 11Last Post: 05-18-2005, 04:07 PM -
Where is advance on Indmar's HEI distributor?
By Rusten in forum Service & RepairReplies: 22Last Post: 11-19-2004, 09:47 PM -
tower speaker wires
By seanpatsdad in forum General ChatReplies: 0Last Post: 06-27-2004, 04:44 PM
