I was fooling around with the shower and notice that I dont get any hot water coming out. I feel the red hose is warm right up to the valves. When I have only the hot valve open, nothing comes out. Just the cold open, cold comes out, both open, still just cold. Anybody else have their valves go bad? I know its not essential equipment but Id like it to work just the same.
Results 1 to 3 of 3
09-19-2006, 06:36 PM #1
Senior Member
- Apr 2005
- Madison, WI
- 198
No hot water coming out of shower
Jim Hagen
Madison, Wisconsin
facebook.com/signedgewraps
09-19-2006, 11:00 PM #2
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Replying to Topic 'No hot water coming out of shower'
Rugburn, if your hot water supply is coming from the block, you may have some debris (dirt,rust,sand) build up in there, and it is letting little water through to the valve but with no pressure. Remove the hose from the barb, and on a fake-a-lake, start the motor, see if you have a steady stream coming from the barb. If you do, check the hose at the dial. If you don't, take a drill bit 2 sizes under what will fit in the barb, insert and turn counterclockwise, by fingers, while the engine is running, until the debris comes out. Once a steady stream happens, hook the hose back up and happy showering. Keep us posted. Brian Raymond
09-20-2006, 03:30 AM #3
What kind of type of Moomba did you got the Shower. I am planning to install one myself so any information, manuals, types of showers, place to install is welcome.Originally posted by Rugburn
No Cold water in shower
By hotstore in forum Service & RepairReplies: 1Last Post: 12-14-2006, 03:08 PM -
Shower
By mvd in forum Boat OwnersReplies: 4Last Post: 10-12-2006, 06:43 AM -
Where in the heck is the water coming from?
By Livindadream in forum Service & RepairReplies: 9Last Post: 06-23-2004, 02:38 PM -
boat shower?
By BLKOUTLS in forum Boat OwnersReplies: 8Last Post: 01-22-2004, 06:43 AM -
Shower Install
By waterboy in forum Boat OwnersReplies: 4Last Post: 12-03-2003, 03:01 AM
