Whenever the boat is at the dock during a heavy rain, the ski locker fills with 4 to 6 inches of water that won't drain. Shouldn't the ski locker drain into the bilge? At the "stern end - bottom" of the ski locker appears to be some type of plug (plastic or rubber). Should this plug be removed so water can drain down into the bilge? What is the purpose of this plug?
Results 1 to 2 of 2
Thread: Water in Ski Locker - Kamberra
06-16-2003, 07:53 PM #1
Junior Member
- Jun 2003
- Houston
- 8
RickHouston
06-17-2003, 08:34 AM #2
Member
- Apr 2003
- Ky
- 63
Plug adjustment
If you hold the rubber end of the plug you can screw the handle in or out. Whe you shorten the plug it will get fatter and fit better. Be carefull not to go to tight, makes it a real
B!#ch to get out.
Rear locker size
By byronkoz in forum Sales & InformationReplies: 11Last Post: 02-24-2008, 09:07 PM -
Water in center floor locker
By mschude in forum General ChatReplies: 5Last Post: 07-22-2006, 11:42 AM -
Keeping slime out of ski locker
By atfloyd in forum General ChatReplies: 1Last Post: 07-18-2005, 11:08 AM -
Water in ski locker
By csaj4506 in forum General ChatReplies: 6Last Post: 11-16-2004, 02:54 PM -
LS ski locker modification
By lowdrag in forum General ChatReplies: 3Last Post: 07-08-2004, 02:23 PM
