Results 1 to 2 of 2
    Jul 2006
    Default No Cold water in shower
    Hi:
    Has anyone had any problems getting cold water out of their shower, no problem getting hot(burning hot), but cold just trickles out.
    Rick
    Mar 2003
    s.e. washington state
    Since you get hot water the problem would be between the water pump hose connection and the cold water valve. There may be a restriction at the valve. Remove the hose after the valve, start the engine and see if you have flow. If you don't have flow which is probably the case, remove the connection at the water pump hose and blow compressed air through the water line and valve.
  1. help ... poor cold start
    By Aubrey in forum Service & Repair
    Last Post: 06-17-2007, 10:47 PM
  2. Cold Ride in Mississippi today
    By 04OUTBACK in forum Wakeboarding | Wakeskating
    Last Post: 03-27-2007, 03:05 PM
  3. it's cold!!!
    By qb12 in forum General Chat
    Last Post: 12-01-2006, 06:31 PM
  4. No hot water coming out of shower
    By Rugburn in forum Service & Repair
    Last Post: 09-20-2006, 03:30 AM
  5. cold water
    By Zihuatanejo in forum General Chat
    Last Post: 03-28-2005, 08:11 AM
