I bent my rudder on my 2001 mobius v. I am in the process of removing it and have the plate taken apart without any problem. My problem is removing the rudder shaft from the steering linkage clamp. The clamp had 1 cotter pin and a bolt that tightens the clamp. I have removed them and the clamp will slid up and down on the shaft for a distance of about 1/8". I do not understand why it is moving on the shaft, but I can not fully remove it from the rudder shaft. How do you remove it? Is there a web site that has an exploded view of moomba boats and their parts? Thanks for any help that is provided.
Results 1 to 2 of 2
Thread: moomba mobius rudder problem
06-22-2003, 09:53 AM #1
Junior Member
- Sep 2002
- Paris Texas
- 12
Shawn
06-23-2003, 11:08 AM #2
Junior Member
- Sep 2002
- Paris Texas
- 12
I got it off. The shaft had a burr on it. I had to get some sandpaper cloth and sanded it down. I learned a lesson. Do not hit a brass shaft with anything! It will mushroom and cause you problems. Good Day.
Shawn
1999 Mobius problem
By dewayne6243 in forum Service & RepairReplies: 3Last Post: 06-29-2007, 12:02 AM -
Rudder Alignment
By djustice in forum Service & RepairReplies: 3Last Post: 03-30-2006, 08:54 AM -
Problem with 2000 Moomba Boomerang
By Nihilive in forum Service & RepairReplies: 4Last Post: 07-26-2004, 09:58 PM -
Rudder
By Yellowmobius in forum General ChatReplies: 2Last Post: 09-09-2003, 01:46 AM -
problem with moomba mobius
By in forum General ChatReplies: 0Last Post: 06-30-2003, 06:25 PM
