Just getting ready for the season and oh-oh, boat no go. I charged the battery and turned the key for the first time, all the gauges came on and when I turned the key to tyr to stat the motor all I got was a loud click form under the hood? The boat started and ran fine when I put it away, it was stored in my heated garage and the battery is connected correctly. Any ideas? The boat is a 1997 Outback with the carberated Indmar.
Results 1 to 7 of 7
Thread: Motor won't start
04-07-2007, 06:46 PM #1
Member
- Sep 2006
- Calgary Alberta Canada
- 31
Motor won't start
04-07-2007, 07:09 PM #2
Check the ground cable where it attaches from the batt to the block on the block side. ALso check the connection at the starter (positive side).
Hope this helps
B
04-07-2007, 07:27 PM #3
Check your battery connections and if that doesn't help then check the condition of the battery If you can jumper the battery and it starts then it is either the connection or the battery.
04-07-2007, 07:55 PM #4
Senior Member
- Dec 2006
- Thomasville, GA
- 191
I just changed from a PCM motor to the Indmar so I don't know if this is relevant on the Chevy motor. My old PCM did this and the starter relay switch was bad. Like I said I don't even know if the Chevy motor uses this.
Monty
04-07-2007, 08:14 PM #5
Member
- Sep 2006
- 31
Sorry to have wasted every bodys time, but I tried another battery and it worked fine. After I checked all the connections and fuses. I looked at my charger and it was set on 10amp instead of 2amp charge, so I'm guessing that it was not charged enough even though the dial showed it was (and it didn't take as long as I thought it should). Now I just have to wait for the snow to melt. Thank for all the help.
04-08-2007, 05:30 AM #6
No waste of time.........a fellow boater in need is a fellow boater indeed
I like the easy ones to fix.
B
04-08-2007, 10:10 AM #7
Yea, dead batteries are so common on the lake I have taken to brining one of those portable jump batteries for folks.
I’ve never been dead but I put in a second battery last fall. I hope it will remove my stereo angst when we stop to swim.
SD2
blower motor
By jeff b. in forum General ChatReplies: 5Last Post: 04-29-2008, 11:14 PM -
ETX CAT motor?
By hiqualityH2O in forum General ChatReplies: 7Last Post: 02-06-2007, 11:28 PM -
Blower Motor
By moombamania in forum Service & RepairReplies: 3Last Post: 04-26-2004, 05:21 PM -
TBI or MPI Motor
By Shawn in forum Boat OwnersReplies: 2Last Post: 10-24-2003, 04:11 AM -
Blower motor
By tn_viper in forum Service & RepairReplies: 6Last Post: 06-14-2003, 11:58 PM
