I have a 2001 Pro Mobius with a 5.7L Carb motor. The engine was damaged last year during the winter, and i have since bought a new motor and installed it. I need to know the proper way to set the initial timing on the motor. I know that there is a loop-back adapter and im not sure if its suposed be plugged in to set the timing or removed. Right now i set the initial timing to 10deg adv.. with the loop-back plugged in. But i noticed that there is no advance when i reve the motor up to 3000rpm. After i set the timing should i remove the adapter? Also what is good TOTAL timing setting to look for (does 30-32deg adv. sound about right) Please advise...Thanks
Results 1 to 1 of 1
Thread: Static Engine timing 5.7 Carb
06-24-2002, 03:25 PM #1Guest
5.7 Engine with Carb
By toelke4286 in forum Service & RepairReplies: 14Last Post: 04-23-2008, 09:52 AM -
Purchase timing
By steffano in forum Sales & InformationReplies: 10Last Post: 10-03-2006, 11:22 PM -
Carb engine
By silverski in forum Service & RepairReplies: 5Last Post: 06-27-2005, 06:00 PM -
By aajra in forum Service & RepairReplies: 3Last Post: 08-30-2002, 10:53 PM -
New Carb Engine Just Doesn't Run Right
By in forum Boat OwnersReplies: 0Last Post: 05-30-2002, 04:44 PM
