Results 1 to 8 of 8
    Mar 2007
    FT lauderdale fl
    Default replacing bilge pump
    the bilge pump is broken and needs to b replaced on my 04 lsv. There is very little room to work. any suggestions to make the process a little easier
    Dec 2004
    Cinci-Dayton
    I have never done this on a SC boat BUT
    Generally (maybe not here) they are on a mount to the floor and can be twisted and disconected, undo the hose and buy the exact pump to use the same floor mount.
    Right tight left lose I think.
    SD2
    Mar 2003
    s.e. washington state
    If the housing is OK then you may get by with replacing the pump motor mechanism which usually snaps into the housing unit and splice in the wires. It worked on my 99'.
    Mar 2007
    FT lauderdale fl
    actually there is an issue with the housing and the internals... there just isnt much room to work to replace the pump and i wasn't sure if any one had any tips.
    Dec 2004
    Cinci-Dayton
    I'm not sure how a housing goes bad.
    On my Lund I often take it off, wash the crud out in the lake and put it back. Be sure the thing is realy broke and not just jammed with a piece of junk.
    I'm not sure where mine is on teh Moomba.
    SD2
    Mar 2007
    FT lauderdale fl
    well one of the platic ears that holds the top down has been snapped since we got it, so when the top pops up it pops the float switch too
    Mar 2004
    Martinsville,Indiana
    Are you going in from the engine area or the V-Drive access?Mine was right there when you take off the V drive access.You may have to take off the main water inlet line for easier access.
    John
    Mar 2007
    FT lauderdale fl
    great guys thanks buyin a new one tommorow let u no how the replacement goes!
  1. Replacing rear ballast evac pump
    By CraigB in forum Service & Repair
    Last Post: 08-24-2007, 07:45 PM
  2. Bilge pump
    By kmcg in forum Service & Repair
    Last Post: 06-13-2007, 10:26 AM
  3. Bilge pump
    By silverski in forum Service & Repair
    Last Post: 06-16-2006, 12:24 PM
  4. Bilge Pump
    By wakerider in forum Service & Repair
    Last Post: 03-28-2006, 07:26 AM
  5. Bilge pump
    By mikeoc in forum Boat Owners
    Last Post: 07-29-2002, 07:39 AM
