Just wondering if anyone has run into problems with their ballast pump (There is only 1 pump, right?)
I filled up all 3 ballasts on the weekend then when I went to empty them only 2 emptied. When I flip the switch on the third with the other 2 off there is no reaction. No pump noise, nothing.
Is this most likely a wiring problem? Would the wiring problem be right behind the switches or where is the next place I look for wire connections?
Thanks for any input.
Dan
Results 1 to 2 of 2
Thread: Ballast Pump
05-22-2007, 05:24 PM #1
Junior Member
- Dec 2006
- 17
Ballast Pump
05-22-2007, 05:32 PM #2
Junior Member
- Dec 2006
- 17
OOPs. This post would be more suited to the Service section. I will repost there.
Ballast Pump
By joe98684 in forum Service & RepairReplies: 4Last Post: 07-10-2008, 01:32 AM -
Ballast pump
By Dannad in forum Service & RepairReplies: 7Last Post: 06-04-2007, 07:37 AM -
Where to locate ballast pump
By rosh in forum Service & RepairReplies: 1Last Post: 06-01-2007, 07:32 AM -
Ballast Pump Install???
By jchamlee in forum General ChatReplies: 0Last Post: 07-09-2004, 05:43 PM -
ballast pump
By TheBeeZ in forum Service & RepairReplies: 1Last Post: 07-31-2003, 09:51 PM
