Brian, the rocker switch circuit board keeps coming loose. Is there an easy fix out there to solve that problem?
Thread: Rocker switch circuit board
07-14-2003, 12:55 PM #1
Member
- Sep 2002
- Oregon
- 33
07-14-2003, 01:50 PM #2
Member
- Apr 2002
- Greenfield Indiana
- 79
If I understand you dburroug, I am having the same problem on my 2000 Outback/LS. Most often with the blower rocker switch. After a couple of on/offs the blower will no longer stay on. I have to reach under and press the circuit board back towards the dash to let the switch make good contact again.
Always a fun thing to do. Climb in from a set and put your wet hand into a bunch of electronics to get the blower running.
Would love to hear of a possible solution.
07-14-2003, 02:54 PM #3
Member
- Sep 2002
- Oregon
- 33
mine is the bilge and navigation light switches. Constantly reaching behind the dash to push the board back on. Very annoying.
07-14-2003, 10:48 PM #4
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Cicuit board come looseth
Contact;TechServices at SkiersChoice,(865)856-3035ext.130. They should be able to help you.Brian Raymond
Ballast Rocker Switch----Where to buy?
By Loonytik in forum General ChatReplies: 4Last Post: 05-04-2008, 01:37 AM -
Dashboard switches & circuit board
By jknutsen in forum Service & RepairReplies: 5Last Post: 09-06-2007, 06:15 PM -
Circuit Board Popped Loose
By rickmcd59 in forum General ChatReplies: 3Last Post: 07-12-2005, 04:03 PM -
acc. switch load?
By dprime in forum Service & RepairReplies: 3Last Post: 09-22-2004, 05:47 AM
