    Jan 2007
    Indiana Lake IN
    Default how much weight do I need?
    I have a '02 outback and want to put weight in it for boarding. I can fit a sac in the back locker that will hold 400lbs that I am going to order. Will this be enough to make a difference? I realy dont want to fill my floor space up with sac's. Any in sight on what other people are riding with in this boat would be helpful. Thanks!
    Aug 2004
    Lake Hickory, North Carolina
    If you are speaking of an '02 DD, that locker floor is only recommended for 150#. I do not put any weight in there. If it's a V-Drive forget what I just said.
    1100# will get you a decent wake on an Outback. I'm using the Straight line twins 440# each and a factory bag of 275#.
    I place one of the 440's right in front of the stock bag, then the other 440 in the walkway in the bow for about a 60-40 distribution.
    Hope this helps
    B
    Feb 2006
    Fayetteville, GA
    06 Outback DD
    1200# sofa in the back w/ 400# in the walkway.
    Makes a nice wake.
    I only use the bags when its just the four of us.
    Most often, we have enough phat crew to offset the need.
    Quote Originally Posted by Buttafewcoe
    Hope this helps
    B
    Apr 2007
    s.e. washington
    hey wolf,
    i've also got an 06 outback and was looking at the 1200 sofa. does it work well in the back as a seat as well as weight? how is it for filling up?
    Jan 2007
    Indiana Lake IN
    Thanks for the info on the locker floor. I dont want to go over the recomended weight for that floor as I do have a Direct Drive. You say that 1100lbs makes a good wake however the boat is only rated to 1155lbs. Are you including the weight of passangers in your 1100lbs?
  1. Weigh too much weight???
    By BlunderDownUnder in forum Service & Repair
    Last Post: 07-18-2007, 08:06 AM
  2. tounge weight
    By mfiduccia in forum General Chat
    Last Post: 06-10-2007, 04:58 AM
  3. How much weight?
    By superman in forum General Chat
    Last Post: 05-24-2007, 09:50 AM
  4. 2001 Mobius LS weight with trailer weight?
    By pmarti15 in forum Sales & Information
    Last Post: 05-17-2006, 04:41 PM
  5. Weight of 05 LSV Ballasts
    By sbagley in forum General Chat
    Last Post: 08-11-2005, 02:21 PM
