Does anyone have any tips on changing oil on a Mobius V? I still cant figure out how to get to the oil filter. I removed the ballast tanks but I cant get to the filter to remove.
Thread: Oil Change tips
07-21-2003, 10:05 AM #1
Member
- Sep 2002
- Oregon
- 33
Oil Change tips
07-21-2003, 03:10 PM #2
Senior Member
- Jan 2003
- Clermont, Florida
- 250
Do you mean you can't get the filter loosened? Are you using an oil filter wrench?
Brian
07-21-2003, 04:03 PM #3
Member
- Sep 2002
- Oregon
- 33
oil change
No, I can't get my hand,wrench or anything else to the filter. I can see it but is blocked by a metal fitting with a hose attchaced to either end.
07-21-2003, 10:01 PM #4
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Oil change
This may sound long and a pain in the butt, however, it's not bad. The long metal tube is the transmission cooler, which is attached to a clamp, bolted to the block with a 11/16" hex bolt. First remove the clamp on the water intake side of the cooler, and move the hose out of your way. Then, remove the bolt holding the cooler to the side of the block(do not remove the affixed hoses), and lay it o the side. Then, loosen the oil filter w/a filter wrench, wrap a discarded bread bag around the filter, and loosen the rest of the way. The bread bag will help catch any oil from dripping into the bilge, and make removal of the filter overboard less messy. Be sure to line the underlying areas w/rags or scrap carpet. When installing the new filter, fill it w/new oil first, just under the threads, and rub some around the new gasket b4 installing hand tight. Write the #of hrs. w/a Sharpie on a visible side to keep up w/ oil changes. Then reconnect the above, be sure the clamp is secure on the water intake side of the trans. cooler. Keep me posted if more info. needed, copy of your manual goes out on 7/22. Brian Raymond
07-21-2003, 10:21 PM #5
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Oil change tips
There are some previous posts; How is oil filter changed(6-30), and; Oil change(7-1), you may also want to check out under this heading. Brian Raymond
FAE install tips?
By tlatoani in forum General ChatReplies: 2Last Post: 04-30-2008, 09:24 PM -
Tips for Changing Impeller on LSV
By 04OUTBACK in forum Service & RepairReplies: 35Last Post: 03-03-2008, 10:10 PM -
any tips
By liquidlite in forum General ChatReplies: 9Last Post: 10-23-2007, 09:46 PM -
V-Drive tips
By Yellowmobius in forum General ChatReplies: 3Last Post: 05-07-2005, 08:00 PM -
Tips to get begginers up
By Livindadream in forum Skiing & SlalomReplies: 8Last Post: 10-12-2004, 05:28 PM
