I just bought a Sunbrella mooring cover to replace the factory item that self destructed recently. It is made by Westland Industries, supposedly to factory dimensions, to fit the 2000 Outback and sister hulls. The quality is first rate, the tower cutouts and drawstring work well, but.....
Just like the factory cover, this one seems to be a little 'fat'
in the back where the hull curves into the transom. The adjustable prop rods' even when up fully, don't take out the puddle pockets in the back.
Today's question: What have you all done to support your covers? I've made PVC pipe bows that hook into the pop up cleats and all sorts of Magyver rigs, but I'm not there yet.
How do you keep the rain on the outside?
PS- I would recommend this cover . As mentioned, quality is first rate, water beads off fast, and the color choices were good. I got the best price through Iboats.com.
Results 1 to 2 of 2
Thread: Cover supports
07-22-2003, 08:23 PM #1
Junior Member
- Feb 2003
- 18
Cover supports
07-23-2003, 05:35 AM #2
Senior Member
- Jan 2003
- Clermont, Florida
- 250
I ended up making another prop rod out of PVC, with little foam squares glued on either end. I centered it right behind the engine box, and seems to have done the trick.
Brian
06 lvs cover
By davidl in forum General ChatReplies: 2Last Post: 03-19-2007, 05:57 PM -
Cover help
By AZ_Calling in forum General ChatReplies: 3Last Post: 07-10-2006, 01:55 PM -
Looking for cover
By kamberra02 in forum Service & RepairReplies: 7Last Post: 06-08-2006, 12:49 PM -
Bow Cover
By Will Watters in forum General ChatReplies: 7Last Post: 02-16-2005, 06:51 PM -
Cover supports
By Mainemoomba in forum General ChatReplies: 0Last Post: 07-22-2003, 08:22 PM
