I just bought a 2003 Outback LSV and took it out for the first time yesterday. It had 9 demo hours when I bought it so I went ahead and ran it through its paces. When I got around 40 MPH with the wake plate raised all the way, it started to porpoise like an outdrive powered boat that was trimmed too high. I lowered the wake plate to 25% and that smoothed out the ride to perfection. Even though the wake plate stopped the bouncing, this is my first Vdrive and I don't know if the bouncing is normal or if I have a prob. of some sort. My last boat was a 2000 Mobius direct drive and obviously I never had that type of issue before. If anyone has any experience with this please let me know.
Results 1 to 7 of 7
07-29-2003, 10:23 PM #1
Member
- Jan 2003
- Ventura California
- 31
Porpoising (SP?) at higher speeds
Cola - '03 Outback LSV
07-29-2003, 11:55 PM #2
Member
- Jun 2003
- 37
My V-drive does it. Normal.
07-30-2003, 08:50 AM #3
Junior Member
- Feb 2003
- Chicago
- 12
porpousing
I have a 2001 Outback with the same problem. Since the wakeplate option is not offered, I purchased a single trim tab set-up from a company in St. Louis. I installed the tab and it cured the problem.
Pman
08-03-2003, 05:56 PM #4
You want the plate set as high as it will go at high speeds, should max out at around 75%. Setting it at 0 puts the plate down and the boat jumping is no fun.
Larry L
2003 Outback LSV
08-14-2003, 12:32 PM #5
Junior Member
- Aug 2003
- alberta
- 1
porpoising@ higher speeds
I also have to same problem with my 2000 outback ls
i was told a hydrolic trim package would run around $1000canadian.
any cheaper fixes out their?
08-25-2003, 01:44 PM #6
Junior Member
- Feb 2003
- Chicago
- 12
Trim Tab
I have a 2001 Outback, and to fix the porpousing problem, I purchased a single trim tab (14"widex9"
system with pump from Insta-Trim in St. Louis, MO. They charged me $325. Their phone number is 314-385-7470. Good Luck.
Pman
08-25-2003, 02:10 PM #7
Junior Member
- Jan 2003
- Vancouver , BC Canada
- 18
03 Mobius does the same. I see it as two fold positve, first it allows for a better top speed ( not that this is why we buy these boats ) and at the wakeboard speeds with ballast it natually will sink in more.
Seeking Flatwater
Higher Octane - Better???
By gammapark in forum Service & RepairReplies: 9Last Post: 08-23-2007, 08:10 PM -
Some Strange noise at low speeds
By superman in forum Service & RepairReplies: 2Last Post: 07-06-2006, 07:37 AM -
Vib @ Slow Speeds - Better Prop Pitch, Blades?
By Rusten in forum General ChatReplies: 1Last Post: 05-25-2004, 08:23 AM -
higher price for a v drive
By wavedude69 in forum General ChatReplies: 2Last Post: 04-09-2004, 02:05 PM
