Need to replace starter on my '99 Outback...Indmar says dealer is the only place to get one. Any info. would be greatly appreciated.
Results 1 to 6 of 6
Thread: New starter
08-16-2003, 10:48 PM #1
Junior Member
- Aug 2003
- Arlington, Texas
- 7
New starter
08-17-2003, 07:40 AM #2
Senior Member
- Jul 2003
- 340
Just pull it off and take it to an auto parts store like NAPA. I'm sure they'd be able to find one to match it.
08-17-2003, 04:02 PM #3
Junior Member
- May 2003
- Victoria Texas
- 5
I would take it off and take it to a place that rebuilds starters. Have them fix your unit so you keep your original housings. That way you are assured of a starter that will fit right. If you get another starter you run the risk of the front housing being off a little, which can create a nasty sound while starting. Also be sure they use a new heavy duty solenoid and not a cheap rebuilt one. It will cost more, but it is well worth the money. There are also cheaper new solenoids, but get the heavy duty.
________
vaporgenieLast edited by batman1171; 01-19-2011 at 05:16 AM.
08-17-2003, 06:05 PM #4
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Starter
DO NOT INSTALL an automotive replacement starter, yes it may be cheaper, but there is a reason, same goes for carbs. The starter is a marine approved SAEJ1171 starter, it will not emit sparks, and is built for the marine environment, and is Coast Gaurd approved, without an original replacement(or rebuild), you are now held liable for any issues that may be related to it. I have personnally witnessed a automotive starter mishap on a '67 restored to the hilt Correct Craft, luckily it blew the 2 girls out of the boat with little injury, the boat was totaled. You can probably purchace a starter directly through Indmar(www.indmar.com). Hope this helps. Brian Raymond
10-05-2003, 11:49 PM #5
Junior Member
- Aug 2003
- Arlington, Texas
- 7
New starter
Thanks for the advice, Brian.
The local DFW dealer (Waterski Boats Dallas) pulled the starter & had it rebuilt--runs just like new.
10-05-2003, 11:49 PM #6
Junior Member
- Aug 2003
- Arlington, Texas
- 7
New starter
Starter
By sleepy924 in forum Service & RepairReplies: 8Last Post: 07-17-2009, 04:39 PM -
starter issues
By todd in forum Service & RepairReplies: 10Last Post: 05-09-2009, 10:57 AM -
Delay between turning key and starter engaging
By gdyupngo in forum Service & RepairReplies: 0Last Post: 08-12-2005, 08:24 PM -
Starter
By wdf in forum Service & RepairReplies: 0Last Post: 08-10-2003, 10:33 PM
