After I turn the engine off I can hear the shaft spinning to a stop. Is this normal or something I should have looked at?
THanks in advance
Thread: shaft spinning
08-24-2003, 05:47 PM #1
Junior Member
- Oct 2002
- Ontario
- 13
shaft spinning
2002 Outback 5.7 carb
08-25-2003, 07:07 PM #2
Senior Member
- Apr 2003
- Powhatan, VA
- 316
Can you explain a little bit?
08-25-2003, 08:27 PM #3
Junior Member
- Oct 2002
- Ontario
- 13
Catdog1
Thanks for the reply, The noise almost seems as when the engine was shut off, the prop continued to spin on the still shaft.
I checked the prop and it is for a 1" shaft.
Funny Today I put back on the 3 blade OJ and the noise went away. I guess its just a noise 4 blade prop. I just got it so im sending it back for another.
Check of the key and shaft when prop was removed and no visible damage.
Someone thought the motor might be out of alignment. This can make some 4 blades noiseee.
I let u know how the new prop works.
THanks again2002 Outback 5.7 carb
08-26-2003, 02:38 AM #4
Senior Member
- Apr 2003
- Powhatan, VA
- 316
In neutral with the engine off our 3 blade OJ prop and shaft both spin a little bit in the rare occasion when we are in a river current. But its clearly the shaft and prop, not just the prop.
Problem aside, how does the four blade compare to the three? Can you feel a difference? Am thinking about upgrading and keeping the 3-blade as a spare.
08-26-2003, 11:52 PM #5
Junior Member
- Oct 2002
- Ontario
- 13
Catdog
THe four blade did make a difference for hole shot. I noticed when starting from a deep water start I seem to be up earlier, giving the driver my wife used the same amount of throttle. Didnt notice any difference during dock starts.
Held the slower speeds better also. I was using the OJ 4 blade legend. OJ has a new 4 blade CNC or IMP , its suppose to give you more top end Im told, but I have not had any experience with them.2002 Outback 5.7 carb
Drive Shaft
By VA LSV in forum Service & RepairReplies: 6Last Post: 05-06-2008, 08:31 AM -
Prop shaft mount
By tkderose in forum General ChatReplies: 10Last Post: 04-25-2008, 10:29 AM -
Propeller shaft
By rosh in forum Service & RepairReplies: 3Last Post: 02-01-2006, 08:36 AM -
Shaft Packing
By qb12 in forum Service & RepairReplies: 8Last Post: 06-10-2005, 05:47 PM -
Shaft Size
By bryanen in forum Service & RepairReplies: 4Last Post: 10-01-2004, 09:43 AM
