I'm looking for some advice. I have an 06 LSV with the GIII Ballast. Here are my problems.
1) When filling my rear port ballast bag, my center bag also fills. I figure there is some valve or something not working correctly here... where is it located? Something I should be able to get at and work on myself?
2) Stereo has gone wonky. I have the stock system with the kenwood unit in the glove box, 4ch amp, sub, and 4 tower speaker bar. I have the driver's wired remote, and use the cd changer adapter to power and wire up an iPod. Some days it works fine. Others, the buttons on the unit front stop working with just the volume on the remote working. Then, a couple hours in, even the buttons on the remote stop responding, all the while blaring music with no way to adjust volume or change inputs. I figure this is a headunit replacement, but thought I'd post in case others had thoughts.
Results 1 to 3 of 3
07-01-2008, 03:45 PM #1
Junior Member
- Jun 2006
- 4
06 LSV: two issues. ballast and stereo
07-01-2008, 11:04 PM #2
Senior Member
- Oct 2004
- Marietta, GA
- 295
Sounds like you need a new head unit. As for the ballast go back under the transmission cover and make sure the little black lever near the black silonoid(SP) are laying down flat.
Aqua2005 Moomba 23 XLV
340 HP, Clarion 5 HU, 2 Clarion wired digital remotes, 2 Wetsounds 485's, 6 Wetsounds XS 650's, 1 JL 12w6 Sub, 1 Wetsound WS420, 2 JL 300/2amps, 1 Wetsounds Sync 4 amp, 1 JL 500/1 amp. Teak swim platform, Perfect pass. Flip up Bow Light, Chrome tower Nav Light, Chrome thru hulls, Black Bimini, 2 750 Flyhigh bags, 1100 center Flyhigh bag, Acme 1235 14.25 x 14.5 prop, Dual battery system. Evolution Cover. Chrome Blower Vent Covers.
07-01-2008, 11:44 PM #3
Junior Member
- Jun 2006
- 4
Thanks for the response! I'll check the toggle on the solenoids next time I get back to her. As for the head unit, yeah, I think I'll take the opportunity to upgrade it. From the other posts on here, sounds like the KDC-X692 is an easy/cheap/convenient upgrade.
