Can someone describe the propeller shaft coupling for me? What maintainance needs to be done on it?
Thanks.
Results 1 to 10 of 10
Thread: Propeller Shaft Coupling
10-10-2003, 12:31 PM #1
Senior Member
- Jul 2003
- Carson City, NV
- 157
10-10-2003, 05:23 PM #2
Senior Member
- Apr 2003
- Powhatan, VA
- 316
There is a coupling, brass on mine, that connects the transmission output shaft with propeller shaft.
I've not yet ever touched it, nor do I think maintenance is required.
Why do you ask?
10-10-2003, 05:47 PM #3
Senior Member
- Jul 2003
- Carson City, NV
- 157
Check out the indmar and boat manual. Both say to annually remove the attaching hardware from the propeller shaft coupling and coat the flanges with multipurpose grease.
Thanks for your help b/c I could not figure out what they were talking about.
10-10-2003, 07:32 PM #4
Senior Member
- Apr 2003
- Powhatan, VA
- 316
Mine is older and doesn't appear to have such guidelines.
Maybe your set-up is different.
10-10-2003, 11:06 PM #5
Member
- Aug 2003
- Canada
- 61
Prop shaft flange
I have older inboard Boats. Once a year I separate this flange to ensure the allignment is correct between the engine and shaft and adjust if neeeded. Theoretically there could be a slight shift in the engine due to collapsing of the engine mounts (or worse) over time. This would put strain on the shaft and also the strut bearing would fail. This may be the reason why they suggest separating the flanges. It makes sense to lubricate them before reassembly however this would just be for anti-corrosion. I have only owned my Moomba for a few months so I have not carried out this check yet.
More important is to check the stuffing box. I was not impressed that the rear seat had to be removed and floor unscrewed to check the fitting. If stuffing box is overtightened (often the case) and fails, water is going to come in quickly! Not nowing the service history of my boat, I checked it regularly for the first few weeks. What a pain.
Tonyboomerang
10-11-2003, 07:07 AM #6
Senior Member
- Apr 2003
- Powhatan, VA
- 316
Thanks. I need to change the strut bearing ( cutlass bearing ), and will now know to check the alignment.
Do you have any tricks for sighting the alignment, and for changing the alignment if needed? Turning the screws looks easy, but I need to be able to assess progress.
Regarding the packing, and extending the thought to all other
water entry points under the floor on the Direct Drive boats...
Out of necessity I found and have practiced a way on the 99 outback to get to these parts fast ( about 60 seconds ). I remove the engine cover and floor as one piece. I never screw the floor down.
10-11-2003, 10:56 PM #7
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Alignment not a problem
Engine to shaft coupler alignments should be done at the begining of every season, this is very important, it will reduce packing gland and strut bearing wear, and eliminate vibration. Your local dealer is able to do this for you when you have the boat dewinterized, or, contact; techservice@skierschoice.com for a faxable instruction sheet for the D.I.Y.er. Brian Raymond
10-13-2003, 10:34 PM #8
Member
- Aug 2003
- Canada
- 61
shaft allignment
There you go! Thanks again Brian. This job is not hard but you need a set of feeler gauges and a little time.
Tonyboomerang
10-14-2003, 12:43 AM #9
Senior Member
- Apr 2003
- Powhatan, VA
- 316
Thanks. Emailed today for the fax.
Any more tips would be appreciated. Targeting this weekend to attack this problem.
10-14-2003, 08:45 AM #10
Member
- Aug 2003
- Canada
- 61
keeping the peace
As I mentioned before, I run a 50's inboard. It is a blast and has been a good ski boat for the family. I rebuilt the boat myself so I have a habit of spending time with my head in the \"oily parts\" just to make sure all is well.
Anyway, when I bought the Moomba at the end of this season I assured my wife that this nearly new boat would need nothing in the way of pampering and TLC. That was the sales pitch and it worked.
The day it arrived on our drive I stripped out the interior and floor just to confirm the low hours and to make sure there were no hidden problems. My wife took one look at the bits of boat all over the drive, shook her head and went back inside. I have tried to keep the service time to a minimum since then. For this season anyway.
The boat did redeem itself the next evening. It was the first night of the blackout and I was out polishing the Moomba. The rest of the family joined me to listen to the radio for news of what was going on. Before long, the neighbours were over with refreshments, making themselves comfortable on board. Our first boat party, right there on the drive.
Tonyboomerang
Propeller for a XLV GG
By TobesDubai in forum Sales & InformationReplies: 3Last Post: 01-18-2007, 12:01 PM -
Propeller
By alex in forum Wakeboarding | WakeskatingReplies: 3Last Post: 06-17-2006, 07:48 PM -
Propeller
By ben624 in forum General ChatReplies: 5Last Post: 04-07-2006, 08:50 PM -
Propeller shaft
By rosh in forum Service & RepairReplies: 3Last Post: 02-01-2006, 08:36 AM -
Propeller
By in forum Boat OwnersReplies: 0Last Post: 05-18-2003, 09:35 PM
