I changed the black box a couple months ago and dont know if htis is related. My bilge pump runs continuously at the low setting. When i put hte float up, then it goes to hi speed. What would cause my bilge to continuously run?????
Is it possible to get electical schmatics for my boat????
Second question, what does it take to replace the seal on teh shaft??? i have had immense problems withleakage, even after adjusting the seal to a couple drips ( 10-15) per mi nute. I run it for 10 minutes and it leaks alot. I have adjusted it at least 7 times. It continueally gets out of adjustement
Results 1 to 2 of 2
Thread: Bilge pump
07-27-2002, 05:23 PM #1
Junior Member
- Jun 2002
- Wisconsin
- 9
Bilge pump
07-29-2002, 07:39 AM #2
Junior Member
- Jul 2002
- Woodbury, Tennessee
- 10
shaft leakage
back the jam nut off then loosen the main nut and place wax rope in and around the shaft, retighten the main nut snug with your hand, then an additional 1/4 of a turn and tighten the jam nut.
Bilge pump
By kmcg in forum Service & RepairReplies: 2Last Post: 06-13-2007, 10:26 AM -
Bilge pump
By silverski in forum Service & RepairReplies: 1Last Post: 06-16-2006, 12:24 PM -
Bilge Pump
By wakerider in forum Service & RepairReplies: 5Last Post: 03-28-2006, 07:26 AM -
Bilge Pump Problem?
By scott016 in forum Service & RepairReplies: 13Last Post: 05-26-2005, 09:07 PM -
bilge pump
By pike1990 in forum Sales & InformationReplies: 1Last Post: 09-04-2002, 11:06 PM
