Brian, if you are out there could you tell me what is the brand(and model # if avaliable) of the electric ballast valves used in the 04 mobius lsv bertha 3 bag ballast system.
I need to fix one and it is not pratical to go back to the dealer for a $20 repair(I hope)
Thanks, kcjczrs@yahoo.com
02-18-2004, 02:50 AM #1
mobius LSV ballast pump electric valve
04 Mobius LSV w/320
02-18-2004, 03:08 PM #2
Replying to Topic 'mobius LSV ballast pump electric valve'
Brian Raymond is at Indmar school this week. I'm sure you're wondering why he needs to go to school since he was practically born and raised in a boat
. Anyway the only way you can get the electric valves is to order them through your local dealer. They could have it dropped ship to you and save you the drive.
Regards,
Jay Warren
Mkt Manager
03-08-2004, 12:47 PM #3
Brian, this is a repost from a couple weeks ago; if you could answer this question, it seems that Jay Warren was answering you e-mail and did not want to answer the question
Thanks, kcjczrs@yahoo.com04 Mobius LSV w/320
03-10-2004, 10:44 PM #4
Administrator
- Aug 2002
- Maryville, Tn.
- 382
K-N-C, I apologize for the delayed response. What exactly are the symptoms that you are having? (A)Bag fills when system off and driving.(B)Bag fills to slow.(C)When turned on, pump runs but solenoid doesn't click.(D)Solenoid clicks, but pump doesn't run.(D)No power to switch(lights in switch cover do not illuminate when on fill or drain). Did this issue occur slowly, or everything was fine last time out? Please varify batt. voltage and ground at the affected solenoid and pump. Check the ballast fuse panel under the dash and make sure there are no blown fuses or loose connections. Please keep me posted. Brian Raymond
Ballast Pump
By joe98684 in forum Service & RepairReplies: 4Last Post: 07-10-2008, 01:32 AM -
Ballast pump
By Dannad in forum Service & RepairReplies: 7Last Post: 06-04-2007, 07:37 AM -
Ballast Pump
By Dannad in forum Sales & InformationReplies: 1Last Post: 05-22-2007, 05:32 PM -
ballast pump
By TheBeeZ in forum Service & RepairReplies: 1Last Post: 07-31-2003, 09:51 PM -
Electric fuel pump
By wdf in forum General ChatReplies: 3Last Post: 06-19-2003, 10:22 AM
