I want to add fresh water strainer to my boat, '02 OB LSV. From what I understand there is a strainer in the transmission cooler but have not checked. If so, that one would be a beetyoch to check/clean regularly.
I am not sure of the measurement of the Sherwood strainer with the elbows so I am hoping someone has been there before and can add some insight.
I prefer not to move the fitting on the vdrive just from the fear factor. The one picture I found had the fitting on the vdrive turned up but it appears on my rig there is not even enough room with my floor cover. I don’t see an option as to locating after the vdrive either prior to the trans cooler.
I currently see 2 options. I am not sure of the effect of adding the extra 90’s but it seems option 2 would be the best.
Results 1 to 10 of 16
Thread: Project - Fresh Water Strainer
03-31-2009, 08:49 AM #1
Senior Member
- Oct 2008
- Arkansas
- 437
Project - Fresh Water Strainer...thoughts?
04-01-2009, 02:26 PM #2
Senior Member
- Oct 2008
- Arkansas
- 437
Looking for advice.
Surely someone in the klan has added one after the fact.
04-01-2009, 11:25 PM #3
Look at my pictues. I had added 3 on my boat for new ballast pumps.
04-05-2009, 09:52 PM #4
Senior Member
- Oct 2008
- Arkansas
- 437
We did our first ever boat ride this weekend in our new to us boat. Water Temp was 61' and air was 75. The boat temp was a little below 180'. I decide to check the transmission fluid cooler screen. I will definitly be adding a pre vdrive water strainer, some how.
04-06-2009, 08:44 PM #5Sled491 Guest
I have all the parts for just such a project and was about to start. I'm afraid I will be of little help as I have a DD. But I will post pics anyways.
I have a similar problem as the sand I suck up getting on and off my lift eats a coolant hose every season.
04-06-2009, 08:45 PM #6
Member
- Aug 2007
- Lake Webster
- 66
I have a DD setup. My Sherwood strainer with the 90 degree elbows is around 9 inches long and the canister and housing are 7 1/2 inches tall.
04-06-2009, 09:01 PM #7Sled491 Guest
Do you have any pics? I was given 2 90 degree elbows with mine as well, but for the life of me I can't see why I would need them.
04-06-2009, 09:51 PM #8
Member
- Aug 2007
- Lake Webster
- 66
water strainer
I had a natural bend at this point in the intake thus two 90s were possible along with another 90 which was easily purchased at the hardware store. I would have preferred only having one 90 but needed additional for my setup. I have not had any water flow problems.
04-06-2009, 10:30 PM #9
02 mobius lsv
here is pictures of my filter in my lsv
04-06-2009, 11:05 PM #10Sled491 Guest
I see you have it at the rear by the tranny. I was thinking that I would go closer to the front closer to where my fresh water pu line turns back up to the water pump and put it there, but know I will look at the Hull PU and see how that works, thanks
PS sorry for the steal
