Results 1 to 3 of 3
    Default Wakesurfing on XLV Gravity
    A buddy of mine just bought a used 2006 XLV gravity games edition. It has the stock ballasts etc that came with the boat. Can we wakesurf with the stock equipment? What size bags are in the front and rear? Thanks in advance for any suggestions.
    -JW
    Sled491 Guest
    We were able to surf behind a 07 Outback DD with just scuba equipment piled in the corner.
    Feb 2008
    Sylvan Lake, Alberta
    If you don't have the 750 lbs Fly Highs, make the upgrade in the rear. It's an easy, fairly cheap swap and they are enough to get a legit surf wave. even better, use one of the old sacks on the surf side too, then you'll have a lot of weight and a nice curl. I had the 400's last year in the rear and could surf fine, with the 750's this year its a nice long wave.
