I recently got the boat back from the body shop after some major fiberglass work, and I had to replace the two front motor mounts and noticed that the back mounts were slightly bent, so the motor sits about an inch back farther than it should, therefore the front motor mounts mounting holes do not line up. My question is, after I replace the rear motor mounts, how do I adjust the front or back or both mounts to achieve factory alignment with the shaft and prop? Do I have to take it in to a mechanic? Please help, I'm really looking forward to finally getting on the water this summer.
color=red]I finally got the poor boat back from the body shop, and I must say, the back of the boat looks great. If you didn't see the pics of the wreck from "Skeg Problem" you should go check them out then email me if you want to see the finished product.[/color]
Email: jsmith@sppkg.com
**Wonder if you can use html in this forum...<a href="mailto:jsmith@sppkg.com">Email Me</a>**
Thread: Motor mounts / Alignment
03-11-2004, 11:13 AM #1
Junior Member
- Jan 2004
- Gridley, CA
- 13
Jonathan And Andrea Smith
03-11-2004, 05:32 PM #2Guest
Replying to Topic 'Motor mounts / Alignment'
A while back, I asked something similar regarding my 99 outback.
Here is the reply I got:
"Engine to shaft coupler alignments should be done at the begining of every season, this is very important, it will reduce packing gland and strut bearing wear, and eliminate vibration. Your local dealer is able to do this for you when you have the boat dewinterized, or, contact; techservice@skierschoice.com for a faxable instruction sheet for the D.I.Y.er. Brian Raymond "
They faxed the instructions to me the next day!!!
Hope it works for you. Helluva crash. Glad they fixed it. Have a great season.
03-11-2004, 05:33 PM #3
Senior Member
- Apr 2003
- Powhatan, VA
- 316
I asked something similar a while back regarding my 99 outback. Here's the reply:
They faxed the instructions the very next day! Good luck! Have a great season!
03-13-2004, 12:24 AM #4
Administrator
- Aug 2002
- Maryville, Tn.
- 382
Thank you Catdog. Brian Raymond.
Stress cracks around ski platform mounts
By TN_Boarder in forum Service & RepairReplies: 8Last Post: 05-18-2007, 09:18 AM -
Engine Mounts help???
By JesseC in forum Service & RepairReplies: 5Last Post: 05-16-2006, 08:50 PM -
Alignment was easy
By Catdog1 in forum Service & RepairReplies: 20Last Post: 07-27-2004, 09:01 PM -
strut alignment
By mmoody in forum Service & RepairReplies: 2Last Post: 04-21-2004, 11:43 PM -
Tower Camera Mounts
By SMUMATTMAN in forum General ChatReplies: 0Last Post: 02-08-2004, 08:58 PM
