Page 3 of 20 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 198
Thread: my 08 LSV mods
    Apr 2008
    California
    Brain i'm assuming that sub enclosure is a premade box of MDF? If so in that position you can get water, especially coming over the bow and if it hits that MDF it'll swell and crumble so fast you won't believe it! Being as you can't see it i would recommend you pull it, strip that carpet and coat it twice with resin or spray on truck bed liner.
    You can always put the carpet back on if you wish. I'm just saying ... seen it happen more than once!
    Yep, good suggestions. I built the box and did use MDF, but I coated the box with 3 heavy coats of polyurethane before carpeting. I also put 1" plastic feet on the bottom of the box so there is a gap between the box and floor.
    Apr 2008
    California
    There ya go, that should hold the water demons back!
  4. #24
    Jun 2009
    Minneapolis, MN
    Have you powered up the Fusions yet? If so, how do you like them? Getting good reviews all over the place. What a steal at $115.
    Mine showed up yesterday.
    Sold my Moomba. Currently boat whoring.
    Set Ups - 09 CWB Transcend Platinum w/ 09 Ronix Cells (his) and 08 Liquid Force Angel w/ 08 Alloys (hers)
  5. #25
    Quote Originally Posted by Jeff W View Post
    No, I started drilling holes in the tower but still need to run the wires. Definitely a steal if they sound even halfway decent!
  6. #26
    Jul 2009
    virginia
    Ok, not really a mod but thought I'd show my fake-a-lake. I started with a washing machine drain hose (1" ID with 1 1/4" ID on the end), stuck in a 1" pvc barb fitting and added a hose adapter.
    I'd also like to know where you are connecting that "fake-a-lake".
    I haven't seen pics on this thread...can you post one?
  7. #27
    Quote Originally Posted by svnfightsvn View Post
    Sure - here's a pic from an older thread that shows where to connect. Loosen hose clamp, remove black hose, attach fake-a-lake, tighten down hose clamp.
    http://moomba.com/msgboard/showpost....0&postcount=32
  8. #28
    Default Locking rear storage
  9. #29
    Default ski locker drain plug
    I put this together to keep the backwash from the bilge from entering the ski locker. I couldn't find a plug to fit tight so I picked up an inch and a half marine plug and ground down to rubber to the right diameter. Replaced the nut with a wing nut and cut off the bottom edge to fit.
  10. #30
    Default Fusion speakers - powder coating and rewiring
    More info here:
    http://moomba.com/msgboard/showthread.php?t=9783
