I finaly thought of a cheap and very good fix to the problem of your front ballast bags filling with air.
I know mine fills with air when im driving to the lake and sometimes even on the lake. Resulting in you have to burp the bag and this is such a pain.
What i did was install a valve in the drain line of the front ballast.
Valve $10
Hose $17
Hose clamps $3
Valve fittings $2
Now when im not using the ballast i turn the vale off. Block all incoming air. When i want to drain my ballast i open the valve and the water drains out. When you filling the ballast you can open this valve and the over flow feature still works as this is strictly an open or closed valve.
Only thing i didn't get to do was i tried to mount some brackets to hold the valve in place but the tube behind it is the engine air tube and i cant drill threw it. I think it might be metal or maybe a brace is there. Eighter way my self tapping screw didn't want to start and i didnt want to force it. From the drivers seat i can lean forward and actuate the valve so im happy.
Results 1 to 10 of 36
Thread: Fixed Front Ballast air issue
08-04-2009, 09:09 PM #1
6 SX65M Cabins
6 XM9 Towers
1 XI 1K Harpoon
2 XI 800.4
1 XI 2500.1
08-05-2009, 06:51 AM #2
Is the air coming from the empty line? I never made the connection... Couldn't you put a check valve there so you don't have to worry about cranking the handle?
08-05-2009, 08:26 AM #3
So the issue is its the drain line from the front bag. When you pull the boat down the highway the shape of the bow is jsut enough to catch air and it fills the front bag with air.
This allows me to close off the line completely stopping any air from filling my bag.
When i am ready to drain the bag i hit the drain and open the valve. Every time i get to the lake i spend 15 minutes taking the bag out and pushing all the air out then placing it back in the locker and filling it. This saves me all that hassle.Malo <--- Means--Evil or Mean One. This explains a lot.
6 SX65M Cabins
6 XM9 Towers
1 XI 1K Harpoon
2 XI 800.4
1 XI 2500.1
08-05-2009, 12:50 PM #4
I have the same problem but didn't put it together till your post. Do you think a check valve would work or would it have to be a ball valve?
08-05-2009, 01:00 PM #5
mmandley--simple and a awsome mod-i was just putting blue painters tape over the outlet to stop air getting in.
13 Mobius LSV
08-05-2009, 03:13 PM #6
Awesome!!! I think this might be my next Mod...
I've been using Cork, 2 for a dollar at Lowes...
08-05-2009, 04:58 PM #7
6 SX65M Cabins
6 XM9 Towers
1 XI 1K Harpoon
2 XI 800.4
1 XI 2500.1
07-23-2012, 01:58 PM #8
When you get the parts, could you post some pics and where you purchased them? Would like.to do this upgrade myself
2005 mobius lsv 2900lbs ballast2005 mobius lsv
07-24-2012, 08:45 AM #9
I believe that setup is exactly what we all have in mind just sourcing the parts seperately to lower the cost
07-24-2012, 03:13 PM #10
Hey ga-lsv05, I just ordered my parts from wakemakers. I got the check valve and wye fitting that brain linked to above. I spent morning going to our home depot and lowes with no luck at finding them. I also ordered the hose from wakemakers. I've used them a few times and gotta say that they are great to work with. I was mainly hoping to find parts locally so that I don't have to wait for the delivery man.
Scott
'07 Mobius LSV Indmar Assault 5.7 Gravity III- 1100 lb. in port locker, 2300 lbs total
