Results 1 to 10 of 14
    Feb 2007
    vancouver, WA
    Default Skiing behind a 06 outback V
    I almost bought the Outback, but everyone else wakeboards, so I got the V, after skiing behind it I kind of wish I got the outback (DD) the bump on the V is pretty big I think, has anyone else come across this and what can i do to tame the wake down for a smaller bump?
    Sled491 Guest
    Do you have a wakeplate?
    Oct 2008
    N.E. Minneapolis
    Might be worth trying a little different line length, maybe shorten up to 22 or 28 off, many times that will get you in front of the 15 off bump.
    Feb 2007
    vancouver, WA
    Yeah, it has a wake plate, i have moved it up and down, when skiing the true ski boat doesn’t use them? im not sure the rope length, i have taken some many sections on and off, i ski about 10 feet back of the tail of the prop wash...
    Feb 2006
    Hamden Ct
    I found shorter line helped.
    Share The Water
    2006 Outback V
    Jun 2009
    Middleburg, FL
    i have the 09 OBV. i ski at 15 off. do you think going to 22 off will help? i know the 09 has a deeper draft, but that wake at 15 off is pretty rough for me.
    '09 OBV-Rockford Fosgate Tower Speakers, Clarion 750 watt additional amp, 10" sub, Rear 750s,
    New Tow Whip: 2011 Toyota Tundra CrewMax Loaded, 20" BMF Novakane 5s on her feet
    Old Tow Whip (but still got her): 1996 Toyota Landcruiser
    Jan 2009
    Lake Wedowee
    We ski behind an 09 OBV also. We played around with the rope length a little but the wake seemed fairly consistent. For now we're at 15 off. I like to wait till later in the day when the gas tank is getting lighter. I'm not sure how much this actually helps but it makes me feel like i'm getting the best possible wake.
    Sled491 Guest
    If you have the wakeplate drop it all the way down, this should help lift the back of the boat a bit and maybe reduce the wake a bit. But this is the oldest debate on the boards, can a V drive ski as good as a DD. We can't have a v drive becuase I don't have enough water in front of my place for the extra draft of a V drive. That being said I've been behind both, and there is no way in heck anyone can convince me your ever going to get a V drive to make a DD wake.
    May 2007
    Naperville, IL
    Quote Originally Posted by Sled491 View Post
    Just out of curiosity, what is the draft difference between an Outback DD and an Outback V?
    Jan 2009
    Lake Wedowee
    Just looked up the difference on the drafts between 09 outback and 09 OBV. according to the "compare boats" page on the moomba website the outback has a 22in draft while the OBV is said to have a 24ft 2in draft. I think there may be a typo in there somewhere though. The OBV page says it's draft is 27in. Has there ever been a DD and V-drive built on the same hull? I'm sure the DD would still have the better wake but by how much.
